Maximum charge pressure exceeded
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
jimbogrey
Post by jimbogrey » Fri Jun 09, 2006 12:14 am
on a vag-com check today I got the above error
can anyone shed any light on what this means
Jimbo
dummi
RE: Maximum charge pressure exceeded
Post by dummi » Fri Jun 09, 2006 2:01 am
limp mode?
MarkB
Post by MarkB » Fri Jun 09, 2006 7:24 am
Max boost presure exceeded, so may now be in limp mode. Normaly happens if you get a boost leak.
Is the car still not running right then?
Mark
jimbogrey
Post by jimbogrey » Fri Jun 09, 2006 11:24 am
It is certainley running better however I would like to do a FATS run sometime, can you help as I assume you have VAG-COM
Jimbo
MarkB
Post by MarkB » Fri Jun 09, 2006 11:27 am
Can do. We could do it at the next meet if you like.
Mark
jimbogrey
Post by jimbogrey » Fri Jun 09, 2006 11:45 am
or alternatively i could run over to you where on the Surrey Hants border are you?
Jimbo
MarkB
Post by MarkB » Fri Jun 09, 2006 12:06 pm
Could do, I'm near Farnham.
Mark
ronaldmacdonald
Re: Maximum charge pressure exceeded
Post by ronaldmacdonald » Fri Jun 09, 2006 12:47 pm
jimbogrey wrote:on a vag-com check today I got the above error
Jimbo
Jimbo, have you got the numerical code - probably a boost leak as mentioned (check all those hoses) or even a duff n75 valve ?
EuroSag
RE: Re: Maximum charge pressure exceeded
Post by EuroSag » Fri Jun 09, 2006 1:57 pm
Had exactly the same thing. Ended up being a duff DV. Good luck
Porsche 997 GT3 - 2010/60
Porsche 997 GT2FS - 2008/58
Peugeot 205 1.9 GTI-S - 1991/J
Audi B7 RS4 Saloon - 2007/07
Audi Q7 3.0TDI - 2011/11
Alfa 147 GTA - 2003/53
Ford F150 Raptor - 2012/62
ronaldmacdonald
Re: RE: Re: Maximum charge pressure exceeded
Post by ronaldmacdonald » Fri Jun 09, 2006 5:41 pm
Gumball3000 wrote:Had exactly the same thing. Ended up being a duff DV. Good luck
Yeah, I replaced both of these as well when I had that code, if you need the part numbers for the 710N's (AUDI TT BOSCH Diverter Valves)then they are:
06A 145 710N
You may as well do both, £15.54+vat each from www.vagparts.com or £35.76 for both delivered to your door. I believe the stealer prices are around £20 each. Worth getting and doing if youve still got the original 6yr+ 710A's IMO
jimbogrey
Post by jimbogrey » Mon Jun 12, 2006 11:02 am
Thanks for all the input.
The car has recently had a substantial amount of work done on it including new turbo's, clutch f hose and TBB(both samco) as well as an endless list of other parts I also fitted Forge DV's recently , are these known to have any problems? It was also pressure tested and showed no leaks at the time which begs the question , how often should you pressure test for leaks?
Jimbo
EuroSag
Post by EuroSag » Mon Jun 12, 2006 7:51 pm
If you've had loads of work done, could it be that something wasn't quite tight enough and has worked loose? If so, probably a question of re-tracing your footsteps.
DavidT
Post by DavidT » Mon Jun 12, 2006 11:27 pm
Pressure test every 5k with oil change is recommended. The more boost you run, the higher the risk of a leak.
I'd take it back to where the work was done for a healthcheck.
Golich
Post by Golich » Thu Jun 29, 2006 8:37 pm
I used to get this every 3 months or so with my previous AMD chipped S4. I had a theory it was related to the forge piston type DVs but never got round to changing them.
Even if its not the DVs - I think the piston type DVs are rubbish - well at least mine were. You could really feel the boost lag between gear shifts. Of course it could have been a boost leak!!
Nige_RS4
Post by Nige_RS4 » Thu Jun 29, 2006 10:08 pm
Max charge pressure exceeded is normally BPV related if you're lucky (or a boost leak if you're unlucky)
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Return to “DTC / VCDS”
