Lubricating a modded or track car, some advice
If you are "modding" your car and adding BHP or using it on track then consider your oil choice carefully as the stock manufacturers recommended oil will not give you the protection that your engine requires.
A standard oil will not be thermally stable enough to cope with higher temperatures without "shearing" meaning that the oil will not give the same protection after a couple of thousand miles as it it when it was new.
Let’s start with the fundamentals. An engine is a device for converting fuel into motive power. Car enthusiasts get so deep into the details they lose sight of this!
To get more power, an engine must be modified such that it converts more fuel per minute into power than it did in standard form. To produce 6.6 million foot-pounds per minute of power (ie 200 BHP) a modern engine will burn about 0.5 litres of fuel per minute.(Equivalent to 18mpg at 120mph). So, to increase this output to 300BHP or 9.9 million foot-pounds per minute it must be modified to burn (in theory) 0.75 litres.
However, fuel efficiency often goes out of the window when power is the only consideration, so the true fuel burn will be rather more than 0.75 litres/min.
That’s the fundamental point, here’s the fundamental problem:
Less than 30% of the fuel (assuming it’s petrol) is converted to all those foot-pounds. The rest is thrown away as waste heat. True, most of it goes down the exhaust, but over 10% has to be eliminated from the engine internals, and the first line of defence is the oil.
More power means a bigger heat elimination problem. Every component runs hotter; For instance, piston crowns and rings will be running at 280-300C instead of a more normal 240-260C, so it is essential that the oil films on cylinder walls provide an efficient heat path to the block casting, and finally to the coolant.
Any breakdown or carbonisation of the oil will restrict the heat transfer area, leading to serious overheating.
A modern synthetic lubricant based on true temperature-resistant synthetics is essential for long-term reliability. At 250C+, a mineral or hydrocracked mineral oil, particularly a 5W/X or 10W/X grade, is surprisingly volatile, and an oil film around this temperature will be severely depleted by evaporation loss.
Back in the 1970s the solution was to use a thick oil, typically 20W/50; in the late 1980s even 10W/60 grades were used. But in modern very high RPM engines with efficient high-delivery oil pumps thick oils waste power, and impede heat transfer in some situations.
A light viscosity good synthetic formulated for severe competition use is the logical and intelligent choice for the 21st century.
Simon
Simon
RE: Lubricating a modded or track car, some advice
So Simon, I know this a loaded question, what is your recommendation..................
I have had my wrists slapped for selling here before so best to contact me off the boards and I will give you a recommendation. My website is a good place to start.
Simon
Simon
Use the code RS246 and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
phone: 01209 202944
From a complete Oil Novice like myself, what do the grades actually mean? Clearly a measure of viscosity, but I would be interested on what scale etc??
Present:...
Past:
Past:
Found this post regarding 10w/60w oil: http://www.gtr.co.uk/forum/upload/showt ... hp?t=45950
S4B5 Avant
Seems my ramblings are oft quoted!
I would not use a 10w-60 unless the oil temps are truly excessive.
Simon
Simon
phone: 01209 202944
phone: 01209 202944
Please let me know oil temps and I will do some viscosity calculations at those temps which will tell us whether it is to viscous at high temps or not.
Simon
Simon
phone: 01209 202944
phone: 01209 202944
I'm using Castrol TWS (used it also in my previous cars - Subaru STI, Audi S3), which in fact is a successor of Castrol RS, and I had to admit that I'm very content with it.
Think it's suitable especially for remapped engines (higher temperatures) and for engines which are working in traffic jams during the summer temps.
So, I can recommend Castrol RWS also for your engine.
Greetings,
Tomasz
Greetings,
Tomasz
