petrol pipes
2.2 I5 20v turbo - 315 bhp
dave993cars
petrol pipes
Post by dave993cars » Mon May 15, 2006 5:38 pm
Hi People
Has anyone ever changed the petrol pipes that run from front to back, I have a leak at the back of the bulkhead where the pipes run down to go to the underside of the car, having taken out the offending pipe(no easy job) :( I find the other two could do with a change also, but it doesn't look too easy , any help would be appreciated.
Dave S
VaudiGR
RE: petrol pipes
Post by VaudiGR » Mon May 15, 2006 6:54 pm
i havent,but i must say that i do have a petrol smell when i turn the aircondition on,or the air fan,and no sign of leak from the engine bay....could that be an indication of a leak?
dave993cars
Post by dave993cars » Mon May 15, 2006 7:26 pm
Hi
My leak was very obvious, there was a smell in the car but when i looked under the car (with the engine running) a small drip of fuel was leaking on to the ground about a third of the way along the chassis.
Dave S
Greg_S
Post by Greg_S » Mon May 15, 2006 10:39 pm
It seems to be a bit of a common problem that they corrode near the front wheel arch behind the heat shield
Bullshit baffles brains
shineydave
Post by shineydave » Mon May 15, 2006 10:52 pm
i just spliced in new sections of pipe using compresion fittings, chop the corroded section of pipe out and take it to a local pneumatics supplier, they keep all the sizes and fittings in stick. on my S2 it was limited to the section of pipe that changed direction up into the engine bay.
dave993cars
Post by dave993cars » Tue May 16, 2006 8:54 am
Thanks guys
I have purchased the pipes from Vag Parts and intend as Dave suggested to put a compression joints in to make it easier to fit all three pipes, I will let you know how it goes.
Dave S
dave993cars
Post by dave993cars » Wed Jun 07, 2006 12:59 am
Hi people
Took me a while but got there in the end, the pipes from Vag Parts come complete with the brackets, I spliced the pipes as they go up behind the heat shield which made it easer to get the pipes down from the engine bay then connected the long sections under the car,
You know how one job leads to another, when under the car I noticed two oil leaks, one from the back of the engine and one at the oil cooler. the oil cooler was a pig of a job as the large inlet and outlet connections were solid I had to hacksaw through the unions and with a large scoket split them in a vice, fitting the new cooler was very easy.
The leak at the back of the engine was the rocker cover gasket, again sounds easy but I did'nt locate the gasket properly at the front behind the timeing belt pulley( should you remove the pulley)? on running the car I ended up with oil all over the front of the engine, any way redid the whole thing and all is now well.
All parts came from Vag Parts and I found them very helpfull, just need front discs done (a bit rusty after winter layup).
Any good specialists in Scotland or North of England.
Sorry to prattel on.
Dave S
harry
Post by harry » Wed Jun 07, 2006 1:02 am
Where in Scotland are ye Dave?
Try Jim @ Star Performance in Kircaldy for specialist VAG services. Comes recommended by fellow forum users.
HTH
H
:thumbs:
And do you really have 993 cars cos that enough for any man if you do.
Practise safe sex & drive a hybrid if you can...
dave993cars
Post by dave993cars » Wed Jun 07, 2006 1:17 am
Hi Harry
I live near Kinross.
I have herd of Star Performance, but thought they did just mapping and chips did,nt think they did servicing.
Regards
Dave S
harry
Post by harry » Wed Jun 07, 2006 1:21 am
The full shooting match as far AFAIK my man. Worth a shot. Jim is a real enthusiast from what I hear and knows his way around our motors. A few of the RS4/S4 lads use him and I'll be throwing some business his way in the not too distant, as I'm growing more fecked off with inconsistent and poor service from main dealers in Aberdeen and Edinburgh, not to mention the unreasonable pricing structure.
VaudiGR
Post by VaudiGR » Thu Jun 08, 2006 9:03 pm
it turns out my petrol smell was coming out of my ignition coils as they had been loose!!!tightend them up,my idle problem and the smell dissapeared!
cool!
Vasilis
