S3 Big Turbo (Downpipe Info needed)
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
Ryan_s3
Post by Ryan_s3 » Sun May 21, 2006 5:40 pm
motec with a s3 will be very difficult as you will need the dbw module,coil pack etc .Not much change out of 4k including mapping. The stock manifold is restrictive especially the s3/tt one it's also prone to cracking. A 300bhp turbo *may* be ok but whats the point?
Image360bhp 342lb/t
david7m
Post by david7m » Sun May 21, 2006 10:03 pm
HHHHhhhhhhmmmmmmm, £4k for a possible 300bhp, when Revo/APR/AMD etc. are about £500 for 270bhp.
Like you say, that doesn't make sense :?
Dave
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
242spot
Post by 242spot » Thu May 25, 2006 7:17 pm
Hey guys.
I expect to probably get around 320 out of it. Yes you could push 350 or even more on the standard block. But dont you jave to start thinking about what its like to drive. I drive it every day to work .... i want it to be responsive not laggy. Remember i said my friend specs turbos for garret, he is responsible for the turbo on the EQ400 EVO im sure he knows what he is on about.
Further yeah your right the MOTEC is VERY expensive, this is something i need to sit down and chat about with motec.... what they can offer over and above a CUSTOM remap. I guess ultimately it comes down to the responsiveness of the car ie how it develops the pwr and when. NOT just how much hp it produces. Im sure all the pro mods do use these for a reason.
As for the manifold ...... Maybe they do crack... hope mine does not anyway. The reason i choose to stay with the original is purely because its easy. I want the turbo to be in the same place for all the plumbing.
My mate from Garret has said perfromance gains are not really worth worrying about.
Any way will let you know how it goes.
Scott
Ryan_s3
Post by Ryan_s3 » Thu May 25, 2006 9:19 pm
Is your mate dino micouris? If so he knows me very well, check out mr2mania site and compare ryans a3 vs evo 6 garrett gt25 ,you want response,there you go.
Image360bhp 342lb/t
Return to “S3 (Typ 8L) 1999-2003”
