S4 install RS4 intercoolers
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
kamming
Post by kamming » Wed May 17, 2006 11:20 am
Is it necessary to change S4 both sides lower and upper hoses when installing RS4 intercoolers? Or just change both the upper hoses will do......... Thank you for your input.
s4woody
RE: S4 install RS4 intercoolers
Post by s4woody » Wed May 17, 2006 11:41 am
when converting to RS4 intercoolers you have to use both top and bottom hoses from either an RS4 with a piece of s4 hose at the joint to take up the diff size in hoses or use RS4 to s4 hoses already made for the conversion..
GARTH ROAD MOT CENTRE LTD
020 83353032
JonnyX
Post by JonnyX » Wed May 17, 2006 1:47 pm
I would suggest getting the hose conversion kit from Forge Motorsports if they still do it. This has the 4 reducing
hoses you will need. You will also need to source the lower intake hard pipe from the RS4 (offside I think). I assume
you realize you will also need all brackets, nuts and bolts etc. I can recommend Dialynx for the install, they did a pretty
good job (relatively speaking) of mine.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Nige_RS4
Post by Nige_RS4 » Wed May 17, 2006 2:07 pm
Samco do a kit for the RS4 IC's on an S4 - about £65 from memory.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
JonnyX
Re: RE: S4 install RS4 intercoolers
Post by JonnyX » Wed May 17, 2006 3:40 pm
Nige_S4 wrote:Samco do a kit for the RS4 IC's on an S4 - about £65 from memory.
Yes, that's the kit I got from Forge.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
davs4
Post by davs4 » Wed May 17, 2006 5:32 pm
Mine too
BRETTCOLLINS
RE: Re: RE: S4 install RS4 intercoolers
Post by BRETTCOLLINS » Thu May 18, 2006 12:11 am
takes over a month to get it,
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
KayGee
Post by KayGee » Thu May 18, 2006 8:40 am
APR pipe kit from ECS does the same job, dearer but usually in stock.
kamming
Post by kamming » Thu May 18, 2006 9:21 am
Thanks guys.
I found APR kit is way too expensive. Samco seems more reasonable. May I know the contact details?
Nige_RS4
Post by Nige_RS4 » Thu May 18, 2006 10:05 am
Try www.forgemotorsport.co.uk - they no longer stock Samco stuff, but might still be able to get the kit for you.
If you don't have any luck with Forge, try contacting Samco direct ... www.samco.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
MarkB
Post by MarkB » Thu May 18, 2006 3:00 pm
Found this and thought it might be helpful... http://www.goapr.com/Audi/support/s4_in ... ctions.pdf
Mark
Users browsing this forum: No registered users and 65 guests
