Indicators turning off
If I put the indicators on on my 2000 B5, they turn themselves off after about 4-6 flashes......this is sitting in a straight line, without moving the wheel and the indicator arm self cancelling.
I don't believe it is the indicator arm contact as it makes no difference if i hold it in position.
The hazards work well...so i concluded it may be a fault with the seperate flasher control unit.
Has any one had this problem before or know where the unit is located, I assume from the noise it is behind the dash.
thanks for any response.
- shineydave
RE: Indicators turning off
i thought the flasher unit was part of the hazard warning switch but i'm open to being proved wrong
- shineydave
It's only a baby, mine's on 122k and going strong. do they always perform the same number of clicks before switching off?, does the stalk return to the centre position if you don't hold it?
Yes, on most recent model Audis, the flasher relay module is integral with the hazard switch. Yours is exhibiting the typical failure pattern - indicators flash becomes intermittent while hazards continue to work perfectly.
Having dismantled the module from my wife's A2 (which has a relay separate from the hazard switch) I find that there are two small relays and little bit of electonic componentry on a circuit board. One relay (single pole) is used for the indicators (and has severely burnt contact), the other (double pole) is used for the hazards, and appears to be pristine.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
Suzuki Carry 660
Dave, stalk stays where it is when in a straight line and returns as usual on self centering of steering wheel, i was only holding it to make sure the contacts were fully home?
peterb, does the hazard switch just pull out of the dash? I could at least make sure the contacts are clen.
Thanks for your valued help guys
2000 B5 S4 facelift, sadly missed...enjoying the 2005 A2 TDi Special Edition though!
- SimonS4MTM
- Top Gear
I managed to get the surround off, using a credit card.......how on earth does the hazard warning switch come out...i couldn't see any clips on it....reluctantant to lever it in case i snap an important small plastic part.......thanks in advance for your help guys...
- SimonS4MTM
- Top Gear
That is correct - the relay is incorporated into the back of the switch.clubsport wrote:Well, I gently levered it out!
It looks like the unit is all in one no sign of a relay?
8D0 941 509 H appears to be specified for the B5 models, including RS4, from 98 to 02. The catalogue description is 'hazard warning light switch relay turn signal/emerg.light'.I looked on search and found a hazard switch part number
8D0 941509H01C
Does any one know if this is for a unit on a facelift car please?
Suzuki Carry 660
Suzuki Carry 660
Users browsing this forum: Google [Bot] and 34 guests
