Fuel Consumption figures
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
DavidT
Post by DavidT » Mon May 08, 2006 8:08 pm
clive.harper wrote:I think we need to start a separate thread if we're going to get into discussing the merits of available fuels... :bigblink:
I think you're right about that, thanks Clive.
CliveH
Post by CliveH » Mon May 08, 2006 8:18 pm
Did the article mention anything about the effects on MPG?
Clive
saf
Post by saf » Mon May 08, 2006 8:21 pm
I think that the fuel scores may vary for each car.
May be better for a cosworth but not for an S4?
I would have thought that because I drove with optimax for quite a while.
When I changed to Tesco 99, I felt a difference in acceleration atraight away. It was an immediatedifference.
Maybe on the cosworth, and the way it works, Shell optimax is better.
tartan_rob
Post by tartan_rob » Tue May 09, 2006 8:22 am
In theory - the make of fuel makes no odds. Higher octane fuel should be more explosive full stop.
FYI - the V6 S4 block has was tuned by cosworth. I have gone back to OPtimax from using Tesco, I found tesco's fuel was loosing me MPG.....or perhaps that was heavier reight foot...LOL.
2017 Kawasaki Z1000
2014 RS6
2014 S1
GrimReaper
Post by GrimReaper » Tue May 09, 2006 3:17 pm
clive.harper wrote:Did the article mention anything about the effects on MPG?
will try and find the original source to see what it says think it was just a bhp figure guide tbh.
I have so far found BP ultimate better for MPG for my style of driving. Optimax is fine for normal journeys but my right foot can be heavy at times and thats probably why i only got 168 miles to £45, damn those quiet B roads :lol: Not able to compare with Tesco 99 as not seen it available yet down in the deepest depths of Cornwall.
KayGee
Post by KayGee » Tue May 09, 2006 5:47 pm
Common miss conception, higher octane rating means it is less likely to ignite, or more importantly less prone to pre-ignition and knocking. This means more power (more boost, more aggressive timing, etc...) can be extracted before the onset of knocking and/or pre-ignition.
Putting 99 Octane in a car correctly tuned for a lower octane will offer no improvement in performance. It needs to be retuned for the higher rated Octane fuel. In the S4s case it will learn within the trim ranges available adjustments.
HTH
Kevin
P.S I use Tesco 99 as it's available and cheap.
Paulm
Post by Paulm » Wed May 10, 2006 1:23 am
Got to agree with Kevin. You take LPG its octane value is 103 ron but its calorific value is less the 95 ron so = less power but more knock protection.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
Dippy
Post by Dippy » Wed May 10, 2006 12:24 pm
Adding to Kevin's post, in addition to being less likely to pre-ignite and therefore allowing more advance to be used, the higher octane fuel burns slower. This means that indeed more energy can be converted thus increasing torque, but also that conversion is smoother so there is less shock to the engine overall.
2001 Silver S4 Avant
KayGee
Post by KayGee » Thu May 11, 2006 3:37 am
Wow two common miss conceptions in one thread...we're on a roll this week.
Octane rating and burn rate are not related, burn rate is a function of several variables, and the two are completely independent. There does tend to be a correlation between higher octane and slower burn rates but that is due to manufacturers blending their products that way.
Sunoco maximal has 116 Octane rating (ron+mon/2) but has fastest burn rate of all their race fuels.
Burn rate is particuarly important with regard to high rpm engines. You need a fuel that ignites in the quickect possible time when your engine is spinning really fast. This factor can have a large effect on what petrol works in one car really well and not well in another.
Dippy
Post by Dippy » Thu May 11, 2006 12:29 pm
Of course returning to the original subject of this thread, for most members who buy their fuel from common sources there is indeed a correlation between higher octane and slower burning.
For others like KayGee who buy Sunoco maximal, you can be happy that you know that the two parameters are indeed independent.
KayGee
Post by KayGee » Thu May 11, 2006 7:24 pm
I wish I could 1. Get it and 2. afford it...tescos 99 for me.
harry
Post by harry » Fri May 12, 2006 4:36 pm
and there aint even a Tesco in Scotland that supplies 99 in my experience
Practise safe sex & drive a hybrid if you can...
Users browsing this forum: No registered users and 143 guests
