Dies in 2nd gear
Dies in 2nd gear
A couple of times when I've been pulling away quite hard and changed into 2nd gear and accelerated hard again, the engine dies for for a moment before pulling again. At first I though it was the traction control, but the light on the dash doesn't come on so I don't think it is.
Anyone else has the same problem?
While I'm having a moan, does anyone elses run as rough as a bears arse when its cold.
I know the dealers were supposed to change the spark plugs at PDI, I'm thinking mine might have slipped through and the original plugs are the problem. Thoughts?
- SimonS4MTM
- Top Gear
RE: Dies in 2nd gear
I changed mine at the weekend, the plug closest to the front of the engine on the passenger side can be difficult to get to, i found that this one looked as though it had not been changed since new. If in doubt, do them yourself or make sure that you always see the old parts.
Bit loath to do it myself if it should have been done at PDI and I don't want the dealer shouting void warranty at me if I change the plugs myself.
RS4 Straight out the box - gone
S6 5.2 V10 Avant (It's for the kids you know
- SimonS4MTM
- Top Gear
dies in 2nd gear
mine dies in first,(when you floor it ) second, and third when changing up quickly from high revs.Turning off the ESP stops it .
Went to the dealers and they test drove it, booked it into be checked out for a day on the computer and said will call audi with a "dis" report and see if they are aware of the problem and have an upgrade for the management system or the t/c system . couldn't have been more helpful or appologetic.
RE: dies in 2nd gear
Im not sure if this is a similar problem to which the Golf R32`s suffered... seems to sound the same to me..... the engines power delivery hesistates under load when pulling away etc... a new ecu mapping cured the problem and transformed the car! It took alot of us on TSN to log this fault with VW before the UK`s master techie at HQ investigated the problem... VW Germany knew so a new mapping was made.
Hope mine doesnt have this problem
Riz
Riz
I`m just a hardcore petrol head -
nuthintoprove
Dies in 2nd gear
Mine too, give her the holley from 2000 revs in 2nd or third and she stalls momentarily. 2 outa 3 times.
By the way, My dealer, Agnew Belfast, told me the engines were bench tested and she dosnt need run in, but im not taking any chances.
I've not had any of the symptoms you guys are talking about so sounds a bit strange and I do boot mine quite alot?
Live long and floor it
Re: Dies in 2nd gear
Wouldn't trust a word they say.......... Agnews are the biggest shower I have ever come across. I bought my B5 from them and they were so inept it was a laugh....nuthintoprove wrote:By the way, My dealer, Agnew Belfast, told me the engines were bench tested and she dosnt need run in, but im not taking any chances.
RE: Re: Dies in 2nd gear
where u boys from?? im from moira!
Users browsing this forum: Google Adsense [Bot] and 144 guests
