Doors autolock-should they after stopping then moving again?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
david7m
Post by david7m » Thu Apr 20, 2006 12:37 pm
Hi
An ADT set my S3 to lock when it gets to about 15mph, which is does. If I stop to let a passenger out without turning the engine off, they can either pull the door handle twice or I press the button on my door to open everything.
When I pull away (remember engine hasn't stopped!) they do not lock again :( Should they?
My girlfriends 2000 Golf does .....
I thought mine would be the same, if not better :wink:
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
MarkB
RE: Doors autolock-should they after stopping then moving ag
Post by MarkB » Thu Apr 20, 2006 2:05 pm
My S4 doesn't...
Mark
shineydave
Post by shineydave » Thu Apr 20, 2006 9:32 pm
mine doesn't either, seems a bit silly really. i'd expect it to re-lock all the doors, maybe there's a Vag-Com setting that changes the function
david7m
Post by david7m » Fri Apr 21, 2006 4:22 pm
Just seemed strange that a VW does and Audi doesn't.
davidhodgkinson
Post by davidhodgkinson » Fri Apr 21, 2006 7:46 pm
mine doesn't either
Audi 80, Audi Coupe, Audi A3 1.8T All gone :-(
2001 Audi S3 :-) Lots of fun
Honda FireBlade
CliveH
Post by CliveH » Fri Apr 21, 2006 8:48 pm
nor mine - at least we're all consistently surprised :shock:
Clive
david7m
Post by david7m » Mon Apr 24, 2006 9:33 am
clive.harper wrote:nor mine - at least we're all consistently surprised :shock:
:D
DuncS3
Post by DuncS3 » Mon Apr 24, 2006 9:55 am
nor mine!
CliveH
Post by CliveH » Mon Apr 24, 2006 10:01 am
OK, so it's pretty conclusive that Audis across the range don't do this, but it's suggested that VWs do - so does anyone know if the basecode can be modified to achieve this? Or are the published tweaks the only possibilities?
Clive
david7m
Post by david7m » Wed Apr 26, 2006 9:17 am
I have no idea ...infact, dont even have VAG COM :-(
peterb
Post by peterb » Mon May 01, 2006 8:25 pm
Well, just to counter this 'all audis ...' statement, I tested my RS6 today - whilst stopped at a roundabout, I opened the driver's door by double pull on the internal handle. Then as I set off, it locked itself again.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
david7m
Post by david7m » Tue May 02, 2006 10:03 am
Doh !!!!!!!!!
CliveH
Post by CliveH » Tue May 02, 2006 10:05 am
There must be a coding fix then...anyone...?
Clive
DavidT
Post by DavidT » Tue May 02, 2006 10:17 am
clive.harper wrote:There must be a coding fix then...anyone...?
Sounds like a question for the Yahoo vag-com list. Are ya volunteering Clive ? ;)
CliveH
Post by CliveH » Tue May 02, 2006 10:19 am
Yes, I'll give it a go - if you give me a clue as to what the Yahoo vagcom list is...
Clive
Return to “DTC / VCDS”
