what Air Filter
what Air Filter
What Air Filters are people using and do you notice any diff from standard.
I want a panel type one. I have had cones in the past and the noise annoys me after a while.
I have done the sportech mod to my air box. anyone logged the diff between standard and say K&N etc?
cheers
Paul
cheers
Paul
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
RE: what Air Filter
Lots of folk running K&N filter panel.......... just go easy with the oil........ it tends to stuff up the MAF sensor if you are tooo generous.........
RE: what Air Filter
Stock OEM panel works really well and is cheap.
RE: what Air Filter
I've been thinking about cutting the underside of the airbox away and have been thinking about using a K&N as I'm not sure how well the OEM filter will handle getting wet, if water does make it up from the wheel arch...
Mark
Re: RE: what Air Filter
Yeah I have come accross that problem before my scooby. I cleaned all the oil out of the filter and it worked fine. Not sure how much it reduces the filtration though.simple1 wrote:Lots of folk running K&N filter panel.......... just go easy with the oil........ it tends to stuff up the MAF sensor if you are tooo generous.........
@mark, I was worried like you so i checked after a good blast in a very wet day and my filter was completely dry. I copied the sportec pic in my gallery
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
RE: Re: RE: what Air Filter
Just what I was planning to do... does it increase induction and turbo noise?
Mark
Yes but only if you listen for it. A passenger in the car would never notice.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
BRETTCOLLINS
- 5th Gear
Brett, does that sit inside the OEM airbox, or is there a shield that comes with it?ITG cone filter kit from MRC is excellent
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
As you have an MRC generic chip, you should ask MRC for advice. It is generally accepted that the OEM air filter is not a restriction unless there are modifications to other parts of the intake system.
2001 Silver S4 Avant
panel filters never going to make that much difference so just go with whatever offers best filtration and doesnt screw your maf. Pipercross use dry foam which may be more MAF freindly. Also BMC do a proper induction kit which looks quite tasty and would (im guessing) give better gains then a panel on its own.
my cars for sale
You thinking of the BMC CDA here Andy?
Clive
360bhp 342lb/t
