RS4 steering wheel
RS4 steering wheel
Am I right in thinking that I need a later Airbag to fit an B5 RS4 steering wheel in my car?
If so where can I purchase one from cheaply?
Mark
Soupie69uk
RE: RS4 steering wheel
I got one of ebay. Cost me about £130.
I now need some sort of bracket which fits inbetween the airbag and the wheel to make the horn springy.
I was watching a wheel on ebay but will give it a miss this time. I take it the airbag plugs straight in??
Mark
TT airbag I believe is the correct one.
TT airbag has that naff dimpled chrome ring thing that seems to be present on everything that is round on the TT. You need an s-line 3-spoke sports wheel airbag from the A4 B6 model range (I believe the same wheel fits the A2, A3 &A6 models too)TT airbag I believe is the correct one.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Soupie69uk
Yeah thats what i got a S-line one.
Need a cable from the airbag to the car though.
Soupie69uk
Here is a pic of the bit you need to fit to the wheel i just found in the gallery.
Anyone know the part no. of the bit fitted to the wheel?
There doesnt seem to be a separate part number - appears to come as part of the wheel.
The part number attached to this bracket is actually the part no. for the wheel.
Clive
Soupie69uk
Have you tried your local Audi dealer? Mine's very helpful and if you get to know the Parts guys, they will often find a way of accommodating unusual requests like this.
Clive
Soupie69uk
No dont really use the Audi dealer.
I may pop in and try my luck as i have had this wheel for about 8 months and been too lazy to get all the other bits required.
Re: RE: RS4 steering wheel
Did you get to the bottom of this Soupie, as i have sourced an RS4 steering wheel and a suitable airbag but am missing the 'bracket'!!Soupie69uk wrote:
B5 S4
RE: Re: RE: RS4 steering wheel
I had the same problem. Bracket comes with the steering wheel and is NOT availible seperatly. I ended up buying a late A4 steering wheel just for the bracket then resold it.
Wide Body S4
