Tyre Pressure
Tyre Pressure
Just had the amber 'RR' light come on, so stopped in at Kwick Fit (You can't get better apparently)
Checked for nails, nothing - no signs of a puncture, pressure was indeed a bit low though. Anyone know why this might happen? Valve seemed OK too.
This was all after faffing about with ramps, as the first one couldn't lift her...
The manager took the job of putting it onto the ramp, amusing if not a little frightening to see the way he shot forward like a cat on fire, (he clearly wasn't expecting that, all the more amusing as he'd just pointed out his new M3 in the car park) After he was done he asked if I wouldn't mind taking it back of the ramp myself!
Anyway, any advice welcome and I'll see if it comes on again...
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
- SimonS4MTM
- Top Gear
RE: Tyre Pressure
When did you last check your pressures? Pressures wil drop over time.
RE: Tyre Pressure
Never. ever. I know I should. I thought these days they were pretty leakproof?
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
RE: Tyre Pressure
Have had pressure drop over time also on previous cars; another instance over the years I had pressure drop after a rather savage pot-hole but no damage to the tyre or rim, it must have tweaked the bead and then re-bedded itself as wehn I topped up the air all was good.
As a matter of interest what pressure do you run at... reccommended 40psi?
Present:...
Past:
Past:
The RS6 is a heavy fast saloon on only average sized tyres, so pressure changes happen fairly often.
I used to check mine weekly & all 4 often needed a top up weekly. The tyre pressure monitor is often a little keen, as every now & again it would display a warning when in fact the tyre pressures were spot on.
You may need to re-calibrate the monitor, so just top all the tyres off to the recommended levels & then reset the monitor via the DIS Menu functions. A drop of about 4psi over just a couple of weeks is fairly normal. Never heard of bigger drops over longer times, but 4-5psi is the average fluctuation.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
The other potential is what my car had. I kept losing 10 psi in nsf every few weeks, wouldn't be gradual, just go down suddenly.
Went to several tyre fitters no-one could fine the problem. Then valve gave way and I had to be trailered home from Bristol. Turns out the valve housing in the alloy wheel had corroded. So I got it replaced under warranty. Just another option.
- SimonS4MTM
- Top Gear
Unlikely as the valve seals by way of an o ring, could be Audi fobbing you off.rs666 wrote:Turns out the valve housing in the alloy wheel had corroded. So I got it replaced under warranty. Just another option.
- Attachments
- 'O' ring valve.jpg (71.57 KiB) Viewed 1752 times
The valves are steel and the valve bodies are alloy hence the threads corrode together and if a valve starts to fail, which they invaribley do over time, you find you can't remove the old valve.
I had three replaced recently because I read that if you get a puncture you should take the valve core out prior to sqeezing in that sealant gunk and then replace the valves and reinflate.
It'd be a bit of a bugger to get a puncture and find you couldn't remove the valves.
I've done 1500 miles since replaceing the valves and the pressure hasn't dropped at all. Prior to this I was having to put in about 3lb every week.
Had new valves at 40K service as the threads had corroded; kindly replaced under corrosion warranty.
Present:...
Past:
Past:
After having my wheels refurbed and new tyres fitted, I found that they were all dropping in pressure - the worst lost 20psi in two days! I tightened all the valves, and the valve inserts and now they are perfect.
None of my valve bodies seem to have suffered from corrosion, despite not having been touched for 34 months/24k miles.
BTW, tyres can't be 'pretty leakproof', unless you inflate with nitrogen. Oxygen molecules can pass through the rubber of the tyre!
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
Suzuki Carry 660
Its funny as I ran 36psi with PZero's and they wore as if they were over-pressure; Whereas I've found the PS2's wear evenly at 40.
Jeeves, where on earth do you get Nitrogen!? do you work for BOC or something?
Present:...
Past:
Past:
Users browsing this forum: Google [Bot] and 117 guests
