Replacing Rear Speakers
Has anyone replaced the rear speakers in the RS4 /S4 / A4 Avant which has the bose system?
If so did you need a special cradle to enable standard speakers to be fitted to the door mount or are there custom fit speakers available. Any leads on specialists to contact would be appreciated. [img]images/graemlins/beerchug.gif[/img]
Re: Replacing Rear Speakers
I would recommend you try these guys - http://www.edworthys.co.uk/
I think this might be what you are looking for.....
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Here are the speakers they suggest...
Not sure how they compare to the Standard/Bose ones. I would be tempted to look for branded ones.
You could also try these guys - www.technicar.ltd.uk - Tell them I sent you, it might help
.RS246 Shop - RS246 Window Stickers and RS6 Keyrings
| Ultima Evolution
Thanks Phil, will do [img]images/graemlins/thumbs.gif[/img]
edworthys - utter crap stay away from them!!!!!
had massive problems with them unable to supply ordered parts then took weeks to get a refund on my credit card!
try www.caraudiodirect.co.uk these guys will sort out what you need.
Simon
Simon
Volume is Nothing without control
Alpine:Focal:VIBE:Atomic
Point noted Simon, thanks and I also appreciate the link. [img]images/graemlins/thumb.gif[/img]
I thought that quite a few of the RS4 guys had uprated their audio systems. Did you leave the OEM speakers in the rear doors and if so what did you do to improve sound quality?
I left in OEM speakers but rewired with uprated speaker cable then these are fed from new Gemini amp
It isnt always the speakers themselves that give a good sound, it depends what is sending the sound to them [img]images/graemlins/033102bigblink_1_prv.gif[/img]
Really the rear speakers do very little, the front door speakers are a good set with tweeter and mid range, the rears are just a basic mid range speaker
depends what you are trying to achieve
Good luck
Good luck
Can't beat a bit of boost!
I have a set of focal utopia in the front and nothing at all in the rear - the focals took muchos work to get in without fouling the windows but the sound is well worth it [img]images/graemlins/smile.gif[/img]
Some additional sound deadening, uprated wiring and a decent source will vastly improve the quality of sound from your OEM speakers.
Simon
Simon
Try BostonAcoustics they have a TT as there show car and do a lot of speakers to fit Audi. Try this
Thanks all [img]images/graemlins/clap.gif[/img]
