Aux water pump replacement
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
SimonS4MTM
Post by SimonS4MTM » Tue Apr 04, 2006 12:44 pm
So, as mentioned in an earlier post, my auxiliary water pump was leaking. Audi wanted nearly £700 to change the pump, so I set about doing it myself.
I purchased the parts from my local Audi dealer, Bury St Edmunds Audi. This is the first time I had used them as I have only recently moved to the area. A top service was provided with any parts that were not in stock being delivered the next day, even when not ordered till 5:45.
The parts that I ordered were;
Aux water pump, 078965561, £83
Diverter valves x 2, 06A145710N, £22
Injector seals x 6, 035906149A, £2.50
Inlet manifold gaskets x 2, 078129717N, £2.80
I would also advise to get the “spider hose”, as this can become brittle, unfortunately I found out about this one too late, 078103235B, about £55.
Also worth getting a new F-hose, 078133784AJ, £11, and TBB unless you have Samco ones.
The job took me around 4 to 5 hours, cleaning parts as I went and also sheltering from the rain towards the end.
SimonS4MTM
Post by SimonS4MTM » Tue Apr 04, 2006 12:45 pm
Firstly I removed the Y intake pipe, once the hoses are removed from both ends, you simply remove the 4 bolts holding it in place and lift away. It is a good idea to tape plastic bags on the pipes to prevent any dirt or stray washers falling into them.
SimonS4MTM
Post by SimonS4MTM » Tue Apr 04, 2006 12:46 pm
Then I set about removing a few connectors for the injectors and other parts. I also removed the exhaust temp sensor control units from the back of the inlet manifold.
Two vacuum hoses were then disconnected.
Once they are removed you can gain access to the bolts holding the inlet manifold to the heads.
SimonS4MTM
Post by SimonS4MTM » Tue Apr 04, 2006 12:47 pm
You can then lift the inlet manifold a prop it up to gain access to the aux water pump. Be careful at this stage as there will be a lot of cr#p around that can fall inside the heads. Block the holes up and then blow the dirt away with an air line, I did not have one so I used a can of air.
SimonS4MTM
Post by SimonS4MTM » Tue Apr 04, 2006 12:48 pm
Removing the pump is the easy bit, just two hoses and a connector.
Re-fitting is a reversal of removal.
You may ask why I had new injector seals, I was told that these can become brittle over time and if you remove the fuel rail then you will need new injector seals. I manage to remove the head just enough whilst leaving the fuel rail in place, so I decided to leave it there (if it aint broke don’t fix it).
Cheers to all on the forum who were on hand to answer any questions before I started this job.
SimonS4MTM
Post by SimonS4MTM » Tue Apr 04, 2006 12:49 pm
s4woody
Post by s4woody » Tue Apr 04, 2006 1:09 pm
well done si..glad to have been a help..
GARTH ROAD MOT CENTRE LTD
020 83353032
SimonS4MTM
Post by SimonS4MTM » Tue Apr 04, 2006 1:24 pm
I have skimmed through the write up a bit and I do have more photo's. If anyone wants to know more, PM me.
tartan_rob
Post by tartan_rob » Tue Apr 04, 2006 1:48 pm
How do you know if pump is buggered?
2017 Kawasaki Z1000
2014 RS6
2014 S1
SimonS4MTM
Post by SimonS4MTM » Tue Apr 04, 2006 1:52 pm
It leaks, as can be seen in the photo's. It looks like the barrier reef.
Or were you joking?
s4woody
Post by s4woody » Tue Apr 04, 2006 3:07 pm
your,ll have water dwn the back of the engine also if u look with a torch between the inlet manifold u can see if its wet in the V of the engine..and even though its leaking that doesn,t mean its not working..just leaking..
020 83353032
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Apr 04, 2006 4:06 pm
Having to change my pump now too, It is leaking.......
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
KayGee
Post by KayGee » Tue Apr 04, 2006 4:08 pm
Time to get the torch out....
s4woody
Post by s4woody » Tue Apr 04, 2006 6:40 pm
i tell ya what simon we mite think of our cars as stealth rockets but that little aux pump is a stealth pain in the arse..there will be a run on batterys now so every1,s torch is working just to check this pump out for leaks.. :thumbs:
020 83353032
davs4
Post by davs4 » Tue Apr 04, 2006 8:05 pm
Could this be the reason my water level drops off from Max to below Min?
