crankshaft oil seal
crankshaft oil seal
just had rear crankoil seal done took it back to garage still had a slight leak there told me the front one needs replaceing now gutted
RE: crankshaft oil seal
if ya front 1 is leaking then do the cambelt cos oil on a cambelt aint good..also the tensioners and water pump..sorry to be the bearer of bad news but its what needs to be done..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
is the leak now on the front? If still rear it could be upper oil pan, rear main seal, valve cover gaskets or cam adjuster seal.
I've had a good amount of leaking on the right rear (valve cover and tensioner seal) for the past year and a half which I intend to fix this spring. no other inconvenience but smell coming inside when not moving.
Users browsing this forum: No registered users and 94 guests
