Standard S3 tracking settings
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
david7m
Post by david7m » Fri Mar 10, 2006 10:24 pm
Hi
Anyone know the standard S3 camber, toe etc. ?
I've had my car 4 wheel lazer aligned today and it now pulls to the left when the wheel is centre :evil:
Took it back and they said it's the tyres ... but it was fine on the way there!!!
I've got the print out with the actuals on.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
triga60
Post by triga60 » Mon Mar 13, 2006 2:47 pm
Complements of autodata the settings you are looking for are as follows:
front track = 0 +- 1.26 mm
Rear track = toe in 1.88 +1.88 - 1.26
front camber = 0.33N deg +- 0.30 deg
rear camber = 0.58N deg +- 0.20 deg
Hope this helps it is very hard to find anyone to do alignment correctly. make sure your tyre pressures are ok and then swap them round to comfirm that this is not the problem and then you can take it back with confidence they are in the wrong.
good luck.
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: No registered users and 58 guests
