Hi guys,
Have a failed rear fog light and want to replace it but cant really see how to get at it. Take it that you take off the inner boot lid lining, but cant see how to do that either and dont want to pull it too much in case I rip it.
Any help appreciated. Thanks
How Do I Get To The Bulb?
- johneroberts
RE: How Do I Get To The Bulb?
Is this a RS4?
you dont say
but its easy if it is
jr
you dont say
jr
Driving is believing
RS246 Founder
Oops my apologies, no its a W reg 2000 S6.
- johneroberts
Problem solved. There is only one working Fog light on a S6. They dont wire up the other one.. go figure !
Audi have only equipped one rear fog light for as long as I can remember - I think the idea is that if there's only one, it's much less likely to get confused with brake lights.
However, on the C5 range, in particular, the fog lights are so far inboard that I can't see a problem with both being operative.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
Suzuki Carry 660
My 1998 S4 has two fog lights that both work. One in each cluster. The wiring is there but the circuit board needs a little bit taken out in order for the bulb to be inserted.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Similar on my 96 A4 Avant. Everything was wired up, so I just inserted a bulb - it was than that I found that the bulb holder wouldn't go back in the lamp housing. I had to remove a small blanking piece from the lamp housing.
Suzuki Carry 660
Suzuki Carry 660
Users browsing this forum: No registered users and 55 guests
