In Theory - NO - think about it, when the shock is off the car, you are shortening and lengthening the extended spring, when its fitted to the car, the car is sitting under its own weight, sprung weight, so when you lower or raise the platforms on your shocks, all your doing is raising and lowering your ride, coz the spring always has the same sprung weight/lenght(or height..??),Golich wrote: Something that's puzzling me about all ride height units. Are you simply lower the height of the car by reducing the amount of pre-load on the spring? By that I mean simply, unwinding the amount the spring is pre-compressed?
If this is the case then surely this results in the car feeling soggy as you introduce more sag into the damper?
unless you get the plasma cutters out -
