I will be picking up my S6 Avant soon, was just thinking or if anyone knows about the audi satnav/tv unit...2 things...
1- With the TV can you by a freeview type adapter, as they the old anologue signal is deemed to be switched off soon
2- I take it the DVD only plays Region2 (UK) dvd discs, or can this be changed to play any region?
Rich
DVD TV & SAT NAV can you do this with it.......
RE: DVD TV & SAT NAV can you do this with it.......
Minus he DVD bit, its a CD navi lol
Blue_Thunder
- Top Gear
Think you can install a freeview unit from an Audi TT, but from what i've read, it's not an easy job.
oh right ok, thanks
I've only seen the TT freeview unit hooked up to the DVD RNS-E, not the older CD RNS-D (probably because they are not cheap).
If you've got the RNS-E then while it is DVD based for the Navigation it will not play DVDs. You will need to fit and use external audio/video connectors to the RNS-E and then use a separate player.
Have a look here http://www.tclsatnav.com/ for more info.
HTH
Grant
HTH
Grant
Good website thanks for the info Cheers!!!
