A groan or sigh from the engine bay after light throttle
Posted: Sat Oct 05, 2019 10:43 am
by ChrisYates10
Hello,
I've noticed that at about 30mph when I come off the throttle, there's a slight 'groan' or 'hmmmmm' from the right hand side of the engine bay. If I slow down to 25mph and gently accelerate, releasing the throttle at 30mph, I can hear it every time. It's not very loud but I wasn't aware of it before.
Has anyone experienced anything similar? Does anyone know what it might be? I thought it might be a turbocharger with a dodgy bearing / imbalance or surplus boost being exhausted.
Any thoughts?
Also, I'm getting a vibration / judder when I brake from 75mph, so I think a pair of discs will need replacing, not sure which end. I've looked at all discs and there's hardly any wear. Could it be anything else?
Thanks,
C
Re: A groan or sigh from the engine bay after light throttle
Posted: Sat Oct 05, 2019 1:04 pm
by Markp
Turbo? Vacuum leak?
And vibration likely to be discs - first sign is typically lightish braking from speed (classic is motorway slip roads). Felt in steering = front, in seat = rear but often surprisingly hard to tell....
May not be new discs required, just pad deposits, which you might be able to fix with some heavy braking. Or a skim if loads of disc left.
Posted: Mon Oct 07, 2019 5:51 pm
by MikeFish
Posted: Mon Oct 07, 2019 7:24 pm
by ChrisYates10
Hi Mike,
Do you think it might be a leaking / ruptured solenoid valve? I've definitely not fitted any of the Forge ones. My memory is bad, but not that bad.
Who do you use to service / repair your car btw?
C
Posted: Mon Oct 07, 2019 11:25 pm
by brab
viewtopic.php?f=76&t=120383
I think you are referring to the same thing.
My car has now 60,000km and it runs just fine, but the noise is still there.
Dealer confirmed the car is OK.
Regarding the discs, just do a couple of hard braking maneuvers and it will stop.
Posted: Tue Oct 08, 2019 8:00 am
by MikeFish
ChrisYates10 wrote: ↑Mon Oct 07, 2019 7:24 pm
Hi Mike,
C
If you had a boost leak I think you would notice the loss in power.
I used to service my car at the main dealers. Might not be the cheapest or even the best but they have known to pay for new engines outside of warranty if its a genuine engine failure and has had full main dealer service history.
For brake pads / discs etc I'd take it to a local specialist.
Posted: Tue Oct 08, 2019 8:30 am
by uplandsway
One tried Mike and didn’t like, back to stock for me
Posted: Tue Oct 08, 2019 1:50 pm
by PSB1
ChrisYates10 wrote: ↑Sat Oct 05, 2019 10:43 am
Hello,
Any thoughts?
Thanks,
C
Has your wife climbed under the bonnet?
Posted: Tue Oct 08, 2019 5:04 pm
by Toady1
Your discs could just be pad material built up on the surface. They need cleaning with an abrasive disc (not grinding disc!!). The noise could just be the recirculating bovs, check your air boxes are together properly.
Posted: Tue Oct 15, 2019 12:49 pm
by ChrisYates10
Thanks everyone for your responses, C
