Driving mode and engine sound setting
RS6108
Post by RS6108 » Tue Oct 07, 2025 10:00 pm
Hi all,
I am new to the rs6 world so I’m finding out some quirks and perks!
Iv notice that in the comfort setting the exhaust flaps open at around 3000rpm
When in dynamic mode the exhaust flaps seem to be open all the time which seems logical. when I put the car into individual mode with everything set to comfort except the exhaust which I have set to dynamic, the exhaust valves don’t open until 2500-3000. Is this normal or should they be open all the time like the dynamic setting.
morski
Re: Driving mode and engine sound setting
Post by morski » Wed Oct 08, 2025 6:31 pm
Hi,
seems right. Works the same way on mine. Either drive it in dynamic all the time or there is a exhaust valve module you can fit wither by Milltek or Akrapovic to have the valves open at any revs
RS6 Performance Ascari blue, Carbon Ceramics, Akrapovic, H&R Anti Roll bars
RS6108
Post by RS6108 » Thu Oct 09, 2025 8:34 pm
ok nice one thanks for that.
RS6108
Post by RS6108 » Thu Oct 09, 2025 8:39 pm
has anyone tried the 11mode controller? seems a lot less expensive than others i have seen
Tadass910
Post by Tadass910 » Sun Oct 12, 2025 11:50 am
Hi all,
Well in my case it’s not good, if you set in individual mode exhaust to dynamic it should be open always, as it’s open always when you set dynamic on your mmi, I bet something is not right
P.s I am using miltek non resonated exhaust
RS6108
Post by RS6108 » Mon Oct 13, 2025 3:16 pm
Is yours stock map?
What year? mine is 2015
Tadass910
Post by Tadass910 » Thu Oct 16, 2025 7:19 pm
Is yours stock map?
My car is 2014 year and April made, and yes it’s stock I only have Miltek none resonated exhaust
RS6108
Post by RS6108 » Thu Oct 16, 2025 7:25 pm
Maybe it’s a software change or something then.
Tadass910
Post by Tadass910 » Thu Oct 16, 2025 7:41 pm
Maybe :roll:
RS6108
Post by RS6108 » Thu Oct 16, 2025 7:47 pm
I do agree, if you set it to on then it should be on! :audibash:
Tadass910
Post by Tadass910 » Sun Oct 19, 2025 7:11 am
Have you tried asking audi?
RS6108
Post by RS6108 » Sun Oct 19, 2025 10:37 am
I could try but finding someone decent to ask is always a little difficult.
RS6108
Post by RS6108 » Wed Oct 29, 2025 9:16 pm
For anyone who’s interested, I spoke to Chris @ modstock today.
He said the cars ECU software will control the exhaust valves to help with back pressure to reduce turbo lag. I race bikes so I know a fair bit about exhaust back pressures, pulses etc. I agree with Chris and I do think he is right.
It makes complete sense and the ECU might not allow full open valves in individual because of this.
Having it dynamic pushes the rpm higher between gear changes etc and because it’s a mode for harder driving then turbo lag from tick over isn’t a problem.
Tadass910
Post by Tadass910 » Fri Nov 14, 2025 11:48 am
Well it’s strange…because when you go to individual mode and then go to exhaust mode you have a choose: comfort or dynamic, if you press dynamic valves always open, same as you set it in mmi from main menu
Richielda65
Post by Richielda65 » Sat Nov 15, 2025 3:24 pm
With mine I have the valves set to open in individual but they will still be shut every time I start it. I have to switch out of and back in to individual to open them.
Hope this helps.
