Thanks ChrisRS6chris! wrote:Outer "holes" on edge of discs are wear indicators for discs....once hole isn't visible anymore(worn down) this is indicating time for change.
Front discs & pads...
Re: Front discs & pads...
For the Brembo wavy discs:
Front 19" dia: 36mm new / 2mm wear limit / therefore 34mm is the minimum thickness
Rear 17" dia: 22mm new / 2mm wear limit / therefore 20mm is the minimum thickness
hope this helps
hope this helps
Users browsing this forum: No registered users and 70 guests
