Advice needed on a sort of turbo!!!
Off topic chat
Harper--D
Post by Harper--D » Tue Dec 18, 2007 12:43 am
Right, heres a question, i was wondering if i fitted 2 of these to my twin engined mini moto (1 on each carb), would it be very beneficial, i will have a 16mm venturi instead of 12mm and will get a huge jet if these are beneficial enough. All serious advice welcome!!!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0175294971
Dave.
White MK2 Golf.. Slightly modified :D
derdle
RE: Advice needed on a sort of turbo!!!
Post by derdle » Tue Dec 18, 2007 5:36 pm
"A sort of turbo"....it's just a fan isn't it? It's level of compression isn't likely to rise with increased engine revs so its effectiveness is going to diminish...if it has any in the first place. "Up to 35% power increase" mmmmm!
If you are going to increase the charge in the crankcase and therefore the cylinder...what will you do about the timing - can that be altered?
Paul
Harper--D
Post by Harper--D » Tue Dec 18, 2007 7:30 pm
Yep! WILL BE INCREASING TIMING BY !) DEGREES AND INCREASE FUELING TO COMPENSATE FOR EXTRA AIRFLOW!
Dave.
mikeyquattro
Post by mikeyquattro » Tue Dec 18, 2007 8:14 pm
Hmmmmm. Unless you can get them spinning at turbo speeds (which I very much doubt) then they will just add weight!
Remember, don't port it too much, my mates was unrideable due to nasty powerband!! He just kept flipping it :bash:
Tomorrow is another day
dummi
Post by dummi » Tue Dec 18, 2007 8:35 pm
well u have an enlarged venturi to induct air better at high speed, so i presume its a high rpm engine in which case this will be a restriction. this would give you low end torque but not a lot more
Harper--D
Post by Harper--D » Wed Dec 19, 2007 4:46 pm
Well, ive decided to buy 2! I will see how well they work and if they aint any good they can go on EBay!
Dave.
lemond
Post by lemond » Wed Dec 19, 2007 8:21 pm
Don't forget the FMIC :notworthy:
'91 230E Merc. Made when Germany knew how!
'99 S4 Saloon Silver. Made after it had forgotten!
S4TAN
Post by S4TAN » Wed Dec 19, 2007 8:24 pm
I is loving your .gif work there lemond :lol:
Deus ex machina
Return to “Off Topic Chat”
