Engine warm up...
Engine warm up...
Am I the only one who likes to stand outside the car when it warms up & eventually reaches that point where the engine makes a wop wop wop sound before dropping the revs?
It's all torque talk.
Re: Engine warm up...
dont do it intenionly but by the time i drive it out of the garage and get out to shut the door again it does the wop wop noise
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Jordan100200
Someone should put a video on of this
AgreedJordan100200 wrote:Someone should put a video on of this
I'll do a before & after once my exhaust has been replaced......
dont see what the difference would be as the sound comes from the engine bay/secondary air valve bypasssmudge wrote:I'll do a before & after once my exhaust has been replaced......
I'm not putting the stock zorst back on, so I would think the overall tone of the system will be different no?eightfoot wrote:dont see what the difference would be as the sound comes from the engine bay/secondary air valve bypasssmudge wrote:I'll do a before & after once my exhaust has been replaced......
- Graeme4130
I always wondered why the noise was different for the first 20 or so secondseightfoot wrote:dont see what the difference would be as the sound comes from the engine bay/secondary air valve bypasssmudge wrote:I'll do a before & after once my exhaust has been replaced......
What's the reason for it doing that ?
when you first start up the valves in the exhaust are open as they run on engine vacuum,fast idle produces no vac untill it goes down off fast idle then then valves close as does the secondary air bypass thats when you hear the fluffing noise as the idle comes down and the vacuum increases closing the exhaust valves and the variable inlet vanes and the secondary air system which helps with the cats warming up by blowing air into the exhaust (but dont quote me as i'm no expert)Graeme4130 wrote:I always wondered why the noise was different for the first 20 or so secondseightfoot wrote:dont see what the difference would be as the sound comes from the engine bay/secondary air valve bypasssmudge wrote:I'll do a before & after once my exhaust has been replaced......
- Graeme4130
Cool, cheers
They always sound much better first thing in the morning. Just a shame you can't boot the freezing cold engine to hear what it'd sound like under power at high revs with everything open
put the gearbox in sport will open the valves or select individual in the mmi car settings and set engine noise to dynamic,think mine is comfort engine,auto everything else,dynamic engine sound,dont think reving it stationary will open the intake vanes thou but you should hear them at about 4000ish rpm as you get increased induction noiseGraeme4130 wrote:Cool, cheers
carsarecool
Replaced?smudge wrote:I'll do a before & after once my exhaust has been replaced......
Does the B8 still limit the revs when cold like the B7 did?
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
- Graeme4130
It does, yeahMacdaddy wrote:Does the B8 still limit the revs when cold like the B7 did?
It'll just change up at 4ish rather than hitting a limiter
carsarecool wrote:Replaced?smudge wrote:I'll do a before & after once my exhaust has been replaced......
Users browsing this forum: No registered users and 134 guests
