Can anyone help me on this? After 20 miles or so i get tpms, electronic handbrake, sports differential and stability warnings all at once. Limp modeis activated, turning off and on gives power back but lights remain until a mile or so down the road. Im thinking from the codes there is a module power issue but i dont know where to start looking. Any help will be much appreciated.
Thursday,07,March,2019,10:14:43:32264
VCDS Version: Release 11.11.3
Address 01: Engine Labels: 079-907-560-CFS.clb
Control Module Part Number: 8T1 907 560 HW: 8T1 907 560
Component and/or Version: 4.2l V8HDZ / H04 0007
Software Coding: 0114000C240F0168
Work Shop Code: WSC 32264 000 1048576
ASAM Dataset: EV_ECM42FSI0118T1907560 001018 (AU48)
VCID: F8F5763943C8EA9
3 Faults Found:
4698 - Function Restriction due to Received Malfunction Value
U1113 00 [044] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Mileage: 133665 km
Date: 2019.03.06
Time: 10:07:22
4699 - Function Restriction due to Received Malfunction Value
U1113 00 [036] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 133699 km
Date: 2019.03.06
Time: 21:00:02
14351 - Throttle Position Sensor Bank 2
P2131 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 133695 km
Date: 2019.03.06
Time: 20:55:04
Readiness: 0000 0001
Thursday,07,March,2019,10:16:15:32264
Address 03: ABS Brakes Labels: 8K0-907-379.clb
Control Module Part Number: 8T0 907 379 HW: 8T0 907 379
Component and/or Version: ESP8 quattro H04 0200
Software Coding: 2C0D2A
Work Shop Code: WSC 06325 000 00000
VCID: FF079D256EE6DD1
3 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 4
Reset counter: 125
Mileage: 133665 km
Time Indication: 0
Date: 2019.03.06
Time: 10:07:22
Freeze Frame:
Hex Value: 0x4100
Hex Value: 0x4006
Hex Value: 0x1226
Hex Value: 0x46B9
Hex Value: 0x00FF
01324 - Control Module for All Wheel Drive (J492)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 125
Mileage: 133665 km
Time Indication: 0
Date: 2019.03.06
Time: 10:07:22
Freeze Frame:
Hex Value: 0x4100
Hex Value: 0x6206
Hex Value: 0x1228
Hex Value: 0x50B8
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 125
Mileage: 133665 km
Time Indication: 0
Date: 2019.03.06
Time: 10:07:23
Freeze Frame:
Hex Value: 0x4300
Hex Value: 0x6206
Hex Value: 0x1233
Hex Value: 0x02B7
Hex Value: 0x00FF
Help
