Electric Steering Column Adjustment
5.0 V10 50v biturbo - 571 bhp
23skip
Post by 23skip » Thu Dec 03, 2015 11:07 am
Has anyone experienced problems with the electric steering column adjustment. Mine has stopped working (Up/down adjustment only, In/Out still works) for the second time. The first time the dealer said I had put too much weight on the wheel when getting in/out of the car, fixed the fault and charged a lot for the fix with no further explanation! Now it has failed again. Is there anything I can do (reset, adjust etc.) to avoid another expensive trip to the dealer?
Any help would be appreciated
Re: Electric Steering Column Adjustment
Post by Shoppinit » Thu Dec 03, 2015 11:36 am
I would check the switch first. Pull it out and check for correct operation with a multimeter. Then I'd look at the motors. Maybe pull the suspect one out and check it. Not sure if it's a stepper motor. Will have a look at the electrical diagrams.
Post by bam_bam » Thu Dec 03, 2015 12:33 pm
C6 not C5, Shop.
Post by Shoppinit » Thu Dec 03, 2015 12:39 pm
Yup. Pretty sure it's the same deal though.
TomRS
Post by TomRS » Thu Dec 03, 2015 12:41 pm
23skip wrote:Has anyone experienced problems with the electric steering column adjustment. Mine has stopped working (Up/down adjustment only, In/Out still works) for the second time. The first time the dealer said I had put too much weight on the wheel when getting in/out of the car, fixed the fault and charged a lot for the fix with no further explanation! Now it has failed again. Is there anything I can do (reset, adjust etc.) to avoid another expensive trip to the dealer?
[09] - Central Electronics
Basic Setting
Prerequisites:
Steering Column or the Central Electronics Control Module (J519) have been replaced.
Approach all 4 end positions (up, down, forward, back).
[Select]
[09 - Central Electronics]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
[Close Controller, Go Back - 06]
Thats what i did on mine when it happened.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
Post by Shoppinit » Thu Dec 03, 2015 12:57 pm
^^That definitely sounds like it's worth a try.
J519 is the module that controls the steering column motors.There are 3 large fuses associated with it, so it's worth checking those, too. 32, 33 and 34 in the left dash panel.
23skip
Post by 23skip » Sat Dec 12, 2015 5:28 pm
Thanks for the suggestions, finally got round to taking a look. TomRS - I presume this need some diagnostic equipment that I don't have access to. Shoppinit - have checked fuses 32, 33, 34 all OK, also 13 (Steering column switch module) and 42 (Steering Column adjustment), also both OK, so no joy. Also now my electric glovebox has decided not to open (I have found the manual override) so looks like I have electrical gremlins. Looks like more expense at the dealer.
Post by Shoppinit » Sat Dec 12, 2015 5:31 pm
Whereabouts are you? Maybe there's a friendly bod with a Vagcom that can check it out / reset it for you.
Users browsing this forum: No registered users and 129 guests
