059919523F is the o e I've ordered from lll parts
Coolant temperature sensor
Re: Coolant temperature sensor
That part number isn't listed for our car. Are you sure it's the correct one?
Sent from my SM-S918B using Tapatalk
Jim Haseltine
The original listed sensor for the RS6 was 059919523A - that was superseeded to 059919523F about 10 years ago.
Update here guys, I had a low battery condition and I think it causes the Temp gauge to not work or something, but if you clear the codes with VCDS (loads after a low batt) then it then comes back to life...
