2008 JDM RS6 VCDS Scan Help
5.0 V10 50v biturbo - 571 bhp
DanT12
Post by DanT12 » Sun Jan 12, 2025 3:51 am
Hi All,
Recently picked up an '08 RS6 into Canada from the Japanese market (RHD).
Had some issues with the MMI not working, screen is on with the 'mute' symbol shown. Managed to figure out that the amp was toast, so in the middle of trying to figure out if an A6 Avant amp of the same style will work.
In the meantime, I got a VCDS cable and ran a scan. Below is the read out. Done some searching, and it looks like most of the faults are electrical components that will take some time to track and fix. All in all though, car drives fine. Just a few options don't work.
Looking for some input from the boffins here to see if there's anything from the scan that raises alarm bells. Nearest dealership is 2 hrs away, and they also have limited exposure to this car as it was never a North American model.
Cheers!
Dan
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 11 31 13 14 15 16 17 19 1E 36 37 42
46 47 4F 52 53 55 56 57 61 62 6C 6D 72 76
VIN: WUAZZZ4F38N902210 Mileage: 107580km-66847miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (BUH) Labels:. 07L-910-552-BUH1.clb
Part No SW: 4F5 910 552 HW: 4F1 907 552 A
Component: 5.0L V10/4V TFSI ª0030
Revision: F1H05--- Serial number:
Coding: 010D0003190F0260
Shop #: WSC 64830 741 54860
VCID: 659069D2196599F2CCD-8030
VINID: 9E546AAAA1160C87890020810024ABD929
No fault code found.
Readiness: 0010 0001
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4F5 910 156 P HW: 09E 927 156 D
Component: AG6 09E 5,0TFSI 280 0020
Revision: --H04--- Serial number: 0002259
Coding: 0000002
Shop #: WSC 02152 785 00200
VCID: 3530F992E9452972BCD-8060
2 Faults Found:
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 93
Reset counter: 255
Mileage: 107556 km
Time Indication: 0
Date: 2025.01.10
Time: 11:21:22
053258 - No Communications with Control Module for Access/Start Authorization
U100A - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 30
Reset counter: 255
Mileage: 107556 km
Time Indication: 0
Date: 2025.01.10
Time: 11:21:34
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AJ HW: 4F0 614 517 AR
Component: ESP8 quattro H01 0130
Revision: 00000000 Serial number: 00000000000000
Coding: 0020931
Shop #: WSC 63810 741 95527
VCID: 6C861CF6FA8FA8BA933-8038
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0090
Revision: 00H05000 Serial number: 10602301132486
Coding: 0000183
VCID: 251029D259E559F20CD-8070
Subsystem 1 - Part No: 4F0 910 132 Q
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H02 0020
Subsystem 3 - Part No: 4F0 910 220 H
Component: FBSAUDIC6 IDG H02 0040
1 Fault Found:
00192 - Rear Left Door Handle Touch Sensor (G417)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 107568 km
Time Indication: 0
Date: 2025.01.10
Time: 17:44:06
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 B HW: 4E0 035 729 C
Component: Interfacebox H41 2090
Revision: 00000000 Serial number: 395G$087504349
Coding: 0001108
Shop #: WSC 02556 785 00200
VCID: 231437CA57D1A7C2629-8076
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001132336
Subsystem 3 - Serial number: 0122.07.080000000100010376ÿ
Subsystem 4 - Serial number: 010376ÿ
1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Mileage: 107568 km
Time Indication: 0
Date: 2025.01.10
Time: 17:53:19
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000549111
Coding: 0529738
VCID: 1C660C366AAF983AA33-8048
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 112
Mileage: 107580 km
Time Indication: 0
Date: 2025.01.11
Time: 14:27:24
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 M HW: 4F0 907 279 A
Component: ILM Fahrer H21 0310
Revision: 00000000 Serial number: 4F0907279
Coding: 0115101
Shop #: WSC 62984 001 1048576
VCID: 3334C78AE7313742929-8066
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0190
Coding: 00064784
Shop #: WSC 62984
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 62984
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2B04DFEA33016F82DA9-807E
Address 11: Engine II Labels:. 07L-910-552-BUH2.clb
Address 13: Auto Dist. Reg Labels: 4F0-910-561.lbl
Part No SW: 4F0 910 561 C HW: 4F0 907 561 B
Component: ABSTANDSREGELUNGH02 0020
Revision: -------- Serial number: 00000000000000
Coding: 0041148
Shop #: WSC 02048 785 00200
1 Fault Found:
02002 - Heater for Distance Regulation Sensor (Z47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01111001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 107565 km
Time Indication: 0
Date: 2025.01.10
Time: 17:27:56
Freeze Frame:
Temperature: 17.0°C
Voltage: 13.06 V
Bin. Bits: 01000
Hex Value: 0x2A11
Hex Value: 0x0002
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
Address 14: Susp. Elect. Labels: None
Part No SW: 4F0 910 376 HW: 4F0 907 376
Component: J250 DRC FahrwerH02 0020
Serial number: 00870000228300
Coding: 0000000
Shop #: WSC 131071 1023 2097151
VCID: 649674D6125FE0FADB3-8030
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0Z6FR+
Coding: 0013382
Shop #: WSC 02325 785 00200
VCID: 290825E235FD7D92285-807C
Subsystem 1 - Serial number: 6332CSME3D344730+
Subsystem 2 - Serial number: 6342CSME3D73345DD
Subsystem 3 - Serial number: 6352QSME7D6E1345U
Subsystem 4 - Serial number: 6362QSME7B07097DW
Subsystem 5 - Serial number: 63734SME750F426B8
Subsystem 6 - Serial number: 63834SME406B0D700
1 Fault Found:
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
014 - Defective - MIL ON
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055081840208
Coding: 0112152
VCID: 270C23DA23E94BE23E1-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
02071 - Local Databus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 107574 km
Time Indication: 0
Date: 2025.01.11
Time: 00:00:46
Address 17: Instruments Labels:. 4F0-920-KOM-V3.clb
Part No SW: 4F0 920 934 N HW: 4F0 920 934 N
Component: KOMBIINSTR. 0900
Revision: 00000000 Serial number: AZ2004JCE
Coding: 3265957
Shop #: WSC 49482 001 1048576
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1000D083258150
Coding: F5D1FEF771260602
VCID: 2D00D1F2011561B2C4D-8078
2 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 110
Mileage: 107562 km
Time Indication: 0
Date: 2025.01.10
Time: 17:15:12
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 107574 km
Time Indication: 0
Date: 2025.01.11
Time: 00:05:39
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8516374
VCID: 1A6A0A2E609BE60AB1F-804E
1 Fault Found:
02446 - Disk Drive Mechanical Malfunction
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 3
Reset counter: 112
Mileage: 107574 km
Time Indication: 0
Date: 2025.01.10
Time: 18:43:28
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0091146
VCID: 61987DC20D4DF5D2305-8034
Address 37: Navigation (J0401) Labels: None
Part No SW: 8T0 919 888 HW: 8T0 919 888
Component: J0401 NAV JP H31 0330
Revision: 0000003S Serial number: AUZBZ7H2707357
VCID: 074C435ACF296BE21E1-8052
Subsystem 1 - Part No SW: 4F0 035 503 B HW: 4F0 035 503 B
Component: ETC-VICS-Ant. H01 0010
Subsystem 2 - Part No SW: 4F0 919 813 B HW: 4F0 919 813 B
Component: Card reader H01 0080
Subsystem 3 - Part No SW: 4E1 910 336 HW: 4E1 862 335
Component: Interface Han H09 0050
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 151
Mileage: 107574 km
Time Indication: 0
Date: 2025.01.10
Time: 22:55:54
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 P HW: 4F0 959 793 P
Component: TSG FA H12 0230
Revision: 00000000 Serial number: ˆ%€
Coding: 0018170
Shop #: WSC 02327 785 00200
VCID: 372CF39AF349DB62AE1-8062
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01130244790000
Coding: 3547897
VCID: 323AC28E182B3E4A99F-8066
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 112
Mileage: 75685 km
Time Indication: 0
Date: 2020.02.03
Time: 07:49:28
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 G
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000006813
Coding: 0011111
VCID: 5EE2463E3C33CA2A0D7-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 P HW: 4F0 959 792 P
Component: TSG BF H12 0230
Revision: 00000000 Serial number: t 
Coding: 0018170
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0008023
Shop #: WSC 02197 785 00200
VCID: 201E38C646C7BCDA7FB-8074
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 63810 741 61718
VCID: 698865E2F57DBD92E85-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 N HW: 4F0 035 541 K
Component: TUNER Japan H42 0180
Revision: 00000000 Serial number: 310GE087512044
Coding: 0000003
VCID: 2B04DFEA3F016F82DA9-807E
Address 57: TV Tuner Labels: None
Part No SW: 4F0 919 148 A HW: 4F0 919 148
Component: R78 DTV-JP 0150
Revision: R0H06000 Serial number: 79300600172602
Coding: 0000316
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVK-Leser 0150
Subsystem 2 - Serial number: 72800600117106
Subsystem 3 - Serial number: 0015.07.08R0H0700000092129ÿ
Subsystem 4 - Serial number: 092129ÿ
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000129518
Shop #: WSC 63848 741 78119
VCID: 241634D652DFA0FA1B3-8070
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2807210352
Coding: 344630393135313035442056413032383037323130333532
Shop #: WSC 00000 384 00290
2 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 107574 km
Time Indication: 0
Date: 2025.01.10
Time: 20:51:53
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2025.01.10
Time: 20:56:13
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0017450
VCID: 2E02D6FE0C131AAAFD7-807A
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8730AF
Coding: 1020505
Shop #: WSC 00000 785 00200
VCID: 1E62063E7CB38A2A4D7-804A
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4F9 910 591 HW: 4F9 827 851 F
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4F9 910 592
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD12.07.08--H25001001C0126ÿ
Subsystem 4 - Serial number: 1C0126ÿ
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0017450
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F1 910 283 A HW: 4F1 919 283 A
Component: Parkhilfe 8-Kan H12 0110
Revision: 00H12000 Serial number: 64320813100204
Coding: 0221116
End----------(Elapsed Time: 02:17, VBatt start/end: 12.4V/12.4V)-----------
IanH755
Re: 2008 JDM RS6 VCDS Scan Help
Post by IanH755 » Sun Jan 12, 2025 11:40 am
Hi there and welcome to the forum!
As the fault logs are stored over time, first thing I'd do is clear all DTC's then drive it for a few days and then scan the fault logs again. This just to make sure that the faults that you've got right this minute aren't just old glitches (all ecu's have them) or old faults which are long since fixed and so the codes you have right now are genuine "its broke right this minute" faults that you can concentrate on. For example some of those faults above are from 2020!
I say this because I've just been working on another guys car which had been in storage for a while (similar to your importing a car) which also had a long list of comms faults and it seems to be that when the battery in these cars dies its flags up lots of "Communication" issues between modules which all need to be cleared from the fault log first otherwise the cars various ECU's & control modules, even though they now have a good battery powering everything, can occasionally still be held in that "I'm broken" mode by these old fault codes, when in reality they're actually fine and after clearing the codes the Module Comms will suddenly spring back into life.
Now, I know that this is not going to clear everything but its a great start to make sure you're approaching whatever faults are left from a clean sheet and not having any old fault codes causing issues.
There will be a few fault codes keep coming back, which I've seen on multiple cars, or are simple fixes -
07-Control Head -- Status: Malfunction 0010 - The J197 module which lives behind the glove box is broke.
13-Auto Dist. Reg -- Status: Malfunction 0010 - Usually needs new ACC sensor in front bumper, check to see if its cracked and let water in.
37-Navigation -- Status: Malfunction 0010 - Antenna connection at the rear roof can corrode, usually needs a new antenna to fix it.
46-Central Conv. -- Status: Malfunction 0010 - H12 Alarm Horn - Theres a small battery inside the alarm horn. Replace the whole horn or just break into the sealed unit and replace the battery.
61-Battery Regul. -- Status: Malfunction 0010 - The cars battery voltage dropped to a low level. The car will auto-shutdown systems to prolong battery life until the battery is recharged.
Hope that helps!
***NEW*** Daytona C6 RS6 Avant - MRC'd - 955HP & 1200NM (PistonHeads Link)
Jim Haseltine
Post by Jim Haseltine » Sun Jan 12, 2025 1:53 pm
Battery - either recharge it using the posts under the bonnet or disconnect it, charge it fully then reconnect and change the code by one digit to fool the module into thinking that it's a new battery.
Door handle touch sensor - replacement handle. You'll need one with the sensor. Can be a sod to release the locking tabs on the handle retainer inside the door.
Driver's air bag sensor - it is a dark brown or black item bolted to the back of the radiator frame about inline with the inner edge of the RH head light and hidden in a metal guard, has a bright yellow multi-plug connected to it. Easy enough to change, disconnect the battery and wait a few minutes to be on the safe side then remove two Torx head screws and pull the sensor back to release a locating pin from the frame.
Alarm horn unit is under the plenum cover, fixed to a bracket on the heater.
Users browsing this forum: lozza2702 and 43 guests
