Thinking of flushing my coolant and replacing , is it a simple job ? Any pointers , like where’s the drain plug and how much fluid does she take
Thanks in advance
Coolant flush and change
Jim Haseltine
Re: Coolant flush and change
No, it isn't - not even if you have use of the vacuum filling equipment.
The drain plug is a hex-headed bolt on the right side of the engine just above and slightly forwards of where the three oil lines mount to the oil thermostat module.
If I remember correctly you need at least 14 litres of coolant in the filling equipment.
SalinaTLombard
Hi all
I found that flushing and replacing the coolant underscores the importance of proper maintenance to ensure optimal performance and longevity of the Audi RS6, as understanding the process and materials required can have a significant impact on the health of the engine.
Users browsing this forum: Google Adsense [Bot], hartley1967, IanH755 and 63 guests
