Zimmerman Discs.. update - help needed re pad sensors
5.0 V10 50v biturbo - 571 bhp
IanH755
Re: Anyone used Zimmerman discs on their C6 RS6?
Post by IanH755 » Tue Oct 18, 2022 10:34 am
The rear OEM pads come with a sensor built in from the ETKA drawing, not actually fitted them myself so have no idea if thats an accurate drawing or not.
Imola_Sid
Post by Imola_Sid » Wed Oct 19, 2022 12:38 am
Ian and Jim - thank you.
I've ordered a full set of Zimmermans and DS2500 pads all round πŸ‘
ATinOf
Post by ATinOf » Mon Oct 31, 2022 1:41 pm
Rear pads are sensor-less
Imola_Sid
Post by Imola_Sid » Thu Dec 01, 2022 8:52 pm
Update...
Had the discs and pads fitted on the weekend (Zimmerman discs with DS2500 pads). I fitted new brake pad sensors and the light wouldn't go on the dash. I tried cutting the plug and joining the wires together but still no luck πŸ˜•
Any ideas?
jnrdavo
Re: Zimmerman Discs.. update - help needed re pad sensors
Post by jnrdavo » Thu Dec 01, 2022 9:00 pm
Do you need to reset in VCDS?
Sent from my SM-G985F using Tapatalk
Imola_Sid
Post by Imola_Sid » Thu Dec 01, 2022 9:41 pm
I'm not sure to be honest...
There aren't any faults or anything showing when checking with Vagcom.
If anyone knows if it needs resetting/how to do it, please share πŸ™
Jim Haseltine
Post by Jim Haseltine » Thu Dec 01, 2022 11:18 pm
It's not a stored code or anything like that, it's simple - as long as the pad circuits are complete the light stays out. I think it was Ian who had a problem with a break somewhere else in the loom that caused the light to stay on.
Imola_Sid
Post by Imola_Sid » Fri Dec 02, 2022 10:42 am
Ah! Sounds like it's going to be a pain to find out where the break is 😬
Jim Haseltine
Post by Jim Haseltine » Fri Dec 02, 2022 1:01 pm
Linky >>>> Pad warning
Imola_Sid
Post by Imola_Sid » Fri Dec 02, 2022 3:46 pm
Thanks mate πŸ‘
IanH755
Post by IanH755 » Fri Dec 02, 2022 11:15 pm
Worst case, track the wires back to the engine firewall bulkhead and try shorting them together there, if it works then you know that the broken wire is in the wing wiring somewhere rather than in the cabin wiring between the ECU and bulkhead.
Imola_Sid
Post by Imola_Sid » Sat Dec 03, 2022 3:26 am
πŸ‘
Imola_Sid
Post by Imola_Sid » Sun Dec 11, 2022 1:40 pm
Turned out that the previous owner had joined the wires in the loom and it had obviously gone bad over time. Sorted it out and no more warning lights. Brakes done βœ… New Oil Level Sensor done βœ… πŸ˜€πŸ˜€πŸ˜€πŸ˜€
Next.. Starter motor and lowering springs.
IanH755
Post by IanH755 » Sun Dec 11, 2022 4:19 pm
Nice, an easy win, rare on these cars :D
Imola_Sid
Post by Imola_Sid » Mon Dec 12, 2022 3:10 pm
πŸ˜€
Return to β€œRS6 / RS6 Plus (C6 Typ 4F) 2008-2010”
Users browsing this forum: No registered users and 188 guests
