Has anyone changed the alternator? Any write-ups hints or tips...?
Alternator
Alternator
So, it seems that a bearing has gone in my alternator.
I have bought a new alternator.
RS6 MTM C6 Avant (Daily Driver)
360 Modena (manual)
F430 Spider (F1)
+ 4 classic Porsches
360 Modena (manual)
F430 Spider (F1)
Jim Haseltine
Re: Alternator
Can't find much info some say it's a front end strip but this thread viewtopic.php?f=47&t=126708&p=866305&hi ... or#p866305 doesn't.
Re: Alternator
Oki, cheers. The thread you linked to was just for the tendioner and belt, not the alternator itself? Or..?
360 Modena (manual)
F430 Spider (F1)
360 Modena (manual)
F430 Spider (F1)
Jim Haseltine
Re: Alternator
Ah, yes - sorry. I was concentrating more on the diagram. Other web searches imply that there's a fair amount of stripping required to get access to some of the fittings.
Re: Alternator
Bumper/undertray off. Headlights out. Pull the front out into “service position”. This gives access to the belt/tensioner and alternator. About a 4hr job in total.
Note that oil / coolant must be drained.
360 Modena (manual)
F430 Spider (F1)
360 Modena (manual)
F430 Spider (F1)
Re: Alternator
Wow, simple job! Isn't the C6 alternator water-cooled?
Re: Alternator
Yes. Watercooled.
360 Modena (manual)
F430 Spider (F1)
360 Modena (manual)
F430 Spider (F1)
Re: Alternator
It is a pig to try and do with the radiators in the service position, book says to remove the rads
RS6, C6, 2009, MRC Stage 2, Aquamist Water/Meth injection, secondary CAT’s deleted, BMC Filters, Headlight Upgrade second projector with RS lens - Trupps supplied the parts I built myself. Interior LED upgrade, C7 RS gear knob upgrade, AutoTecknic Shift Paddle Extensions, KW V3 Coil-overs, H&R ARB's, H&R spacers 8mm Fr & 10MM R.
On the cards - Primary CAT delete, TTE Turbos
