OK I've looked, researched, bought some and tried and failed to find the answer to this.
I'm sure one of you must have solved this long ago, but i give in.
What's the right AMI cable to use in the C6 4f MMI to work with the apple lightning connector?
I've got the yellow (4F0 051 510 AL) and the green (4F0 051 510 AD) connectors and neither play ball.
I'm trying to connect to a 6th gen ipod touch, at a minimum i'm looking for simply music and control (have an older 30 pin ipod that works ok, so expect same level of integration) ideally looking for more than just music for my next plans etc.
So anyone running an apple ipod touch with lightning connector using AMI cable into the MMI? if so what's the part number please?
which apple lightning cable?
Re: which apple lightning cable?
Use the standard cable and stick an adapter on the end.
I use this and it works a treat:
CableJive 60 cm dockXtender Lightning Extension Cable for Apple Devices - Black https://www.amazon.co.uk/dp/B00GP08858/ ... iybN0E4VG1
The phone is attached to the air vents via a magnetic holder. Ticks all the boxes and a simple solution.
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Which magnetic holder do you use Stevo??stevo55 wrote:I use this and it works a treat:
My iPhone 6s just won't work with the MMI so I've been left with no choice but to buy the aux cable and plug it in to the headphone socket.
Steve your car has 3G MMI doesn't it?
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Car has 3G MMI yes. I use a magnetic one I got from Maplins and it's great. It's this one (make sure you get the complete kit with the magnetic plate):
Scosche MagicMount Vent 2 Passive Holder for Smartphone - Black https://www.amazon.co.uk/dp/B00UIABK5G/ ... jyb00MKF54
Current:
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Thanks mate. I think your iPhone works with your MMI because it's 3G.
Maybe worth speaking to Hazzydays to see if they can do anything about that retrofit wise?
Current:
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Users browsing this forum: Bing [Bot], CupraDine, Google Adsense [Bot] and 118 guests
