Air Bag fault
Haggizbasher
- 1st Gear
Air Bag fault
Just had an air bag warning for no reason (that I'm aware off...) on the dash that won't go out....before I take it to the garage and get charged a fortune for switching it off, is there anything I can do or check.....thanks
RS6 C6, Daytona Gray
Q7 4.2 - Sold
Q3 - Wifes car
MV Agusta Brutale 1090RR
Ducati 998S
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Re: Air Bag fault
Check what it is, but apparently it's pretty common.
Reset it with VCDS (as long as it's not something serious)
Haggizbasher
- 1st Gear
Re: Air Bag fault
Thanks... definitely nothing serious, came on for no reason.....
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Re: Air Bag fault
Have you or anyone messed around with the washer jets for the Headlights?
As there is a crash sensor with that, if its not in correctly that can cause a airbag fault.
What ever happens it will need to be reset.
Trups
Trups
Haggizbasher
- 1st Gear
Re: Air Bag fault
Thanks Trups....I've only had the car for a month and never messed with them. The car does get washed regularly, I'll check it out tomorrow morning, thanks....
Does anyone have a VCDS I could borrow....?
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Re: Air Bag fault
Hi, you maybe able to reset the airbag light with a cheap cable from ebay. I'm not sure what airbag module you have on the RS6, but my S4 had the dreaded '65535' error that I couldn't reset with a VCDS cable so I got this and it worked fine.
http://www.ebay.co.uk/itm/VAG-Audi-VW-V ... 1c256f17c6
Haggizbasher
- 1st Gear
Re: Air Bag fault
John, thanks for the info....I've had a look at the link on EBay, my RS is a 2008, not sure if it'll work.....I'll check what module it is.....cheers
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Re: Air Bag fault
Haggizbasher wrote:John, thanks for the info....I've had a look at the link on EBay, my RS is a 2008, not sure if it'll work.....I'll check what module it is.....cheers
It won't work for the 6 fella. Best you scan the car with VCDS to see what's what. You don't want to mess about with airbag faults.
Haggizbasher
- 1st Gear
Re: Air Bag fault
Good advice, I'll see if I can get a VCDS cable and check it out, hopefully nothing serious.....
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Haggizbasher
- 1st Gear
Re: Air Bag fault
Quick up date... I have managed to get a genuine Ross-Tech VCDS cable..... I downloaded the software last night and instructions. Will check it out tonight on the car.... will also look at the VIM
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Haggizbasher
- 1st Gear
Re: Air Bag fault
Plugged in the VCDS cable last night and tried to clear the airbag fault but it kept coming back......did some research on the net and it could be a faulty connector/loose connection. Some of the guys that have experienced the fault have removed the connector and spliced the wires... with success and the fault cleared. I need to remove the back seat to get at the connector and check it out.....just to need to figure how to remove the seats.....
On a positive note... I now have VIM.....
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Haggizbasher
- 1st Gear
Re: Air Bag fault
Update, did some searching on the net and it appears that the connector in the rear for the airbag can cause the airbag light to stay on ( could not re-set with the VCDS) Removed the rear seat, located connector, not a lot to play with. Cut the connector and spliced the wires together.......put the seats back, plugged in VCDS and reset fault.....success...!
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Q7 4.2 - Sold
Q3 - Wifes car
Ducati 998S
Re: Air Bag fault
Nice one!
Yes common prob on early C6's. Think they redesigned the connector on later ones.
Some have fixed it by just using electrical contact cleaner.
