Welcome salamanzer
Not sure about the C6, but did have some trouble fitting non OEM batteries in the C5 due to slightly different sizing, so that would be a consideration for C6 replacement.
On another note, you can also enable the battery level monitor in the MMI. I'll try to find the link.
New C6 RS6 Owner :)
Re: New C6 RS6 Owner :)
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
here: here: http://forum.rs246.com/viewtopic.php?f=47&t=97385
Need a Vagcom, which I can help out with if you are in London, but sure you"ll find someone near you.
salamanzer
I'm in the south west.... i may be able to find someone local.... or absolute worst case a stealer....
This looks to be the battery, if i was to swap it would i have any issues with dropping the power in the car whilst the batteries are swapped, the replacement battery cost is getting picked up by the supplying car dealership
http://www.thebatteryshop.co.uk/610-402 ... 2836-p.asp
Jason
Jason
2008 Audi RS6 C6 - Daytona Grey Avant
the "other" forum has a Vag-Com availability map on itsalamanzer wrote:I'm in the south west.... i may be able to find someone local.... or absolute worst case a stealer....
I did the battery mod on mine, as well as vehicle in motion for the DVD
salamanzer
Any thoughts on this being an issue?
"This looks to be the battery, if i was to swap it would i have any issues with dropping the power in the car whilst the batteries are swapped, the replacement battery cost is getting picked up by the supplying car dealership"
Jason
Jason
I had this.. Battery was replaced under warranty by Audisalamanzer wrote: Seems the battery on the car is dying.... what is the best battery to replace it with? It seems to charge, but not hold on to it for very long.... after a while the boot stops opening and the engine to start is a bit lazy.... once the car is running everything is perfect.
h t t p : / / a u d i s r s.com/about20145.html
Users browsing this forum: Google [Bot] and 162 guests
