Can anyone tell me about my car with these readings ??
AdamS4
Post by AdamS4 » Sat Jul 14, 2007 12:50 pm
This was done in 3rd gear
CliveH
RE: Can anyone tell me about my car with these readings ??
Post by CliveH » Sun Jul 15, 2007 1:39 am
Adam:
Well, you didn't actually get up to 6,500 to calculate a FATs time, but it did take just over 10 secs to go from 4,240 to 6,400 which is far too long.
Your peak MAF reading of 192 is also rather low.
Your actual boost is well below specified all the way up.
I'd hazard a guess at you having a boost leak somewhere is the system. :thumbsdown:
I'm also puzzled by the specified boost as it seems a bit low for a (presumably) stock map :?
Clive
AdamS4
Post by AdamS4 » Sun Jul 15, 2007 6:07 am
Thanks Clive.... all explains here as to why thats all low....
http://www.rs246.com/index.php?name=PNp ... 85c290c136
CliveH
Post by CliveH » Sun Jul 15, 2007 1:00 pm
ah OK Adam - isn't that the sane set of data?? :?
Clive
AdamS4
Post by AdamS4 » Sun Jul 15, 2007 1:33 pm
Yeah, same data cause i posted this post 1st...... then i noticed something was wrong with the boost so i posted again in to give some people some ideas
CliveH
Post by CliveH » Sun Jul 15, 2007 2:34 pm
ok Adam. thread closed then?
I see a split TBB was the problem.
Clive
AdamS4
Post by AdamS4 » Sun Jul 15, 2007 6:46 pm
Thread closed... thanks
Return to “DTC / VCDS”
