Checking oil temp
Philws4
Checking oil temp
Post by Philws4 » Sat May 05, 2007 6:52 pm
Does anyone know which channel/block i can look at to check the accuracy of the oil temp guage?
I don't suspect any problems but would like to know how accurate it is.
TIA
B5 S4
Sebastian
RE: Checking oil temp
Post by Sebastian » Sat May 05, 2007 7:38 pm
Usually the instrument cluster shows the oil temperture in MVB 050.3.
Sebastian @ Ross-Tech.com
Philws4
Re: RE: Checking oil temp
Post by Philws4 » Sat May 05, 2007 11:14 pm
Sebastian wrote:Usually the instrument cluster shows the oil temperture in MVB 050.3.
Can you elaborate? Me not understand!!
B5 S4
DavidT
RE: Re: RE: Checking oil temp
Post by DavidT » Sat May 05, 2007 11:36 pm
Go into instruments which is module 17, then measuring block 050. One temp is water, the other is oil.
Philws4
Post by Philws4 » Sat May 05, 2007 11:39 pm
Thanks DavidT
B5 S4
Return to “DTC / VCDS”
