Help with code please
17930 - Camshaft Adjustment; Bank 2: Malfunction P1522 — 35—10 — — — Intermittent
Readiness: 0000 0000
Only happened once I promise..
Any thoughts?
Any thoughts?
- 1st Gear
RE: Help with code please
Might help if you told people exactly what kind of car and motor this is from.
-Uwe-
-Uwe-
Re: RE: Help with code please
He has a B5 RS4.Uwe@Ross-Tech wrote:Might help if you told people exactly what kind of car and motor this is from.
-Uwe-
RE: Re: RE: Help with code please
sorry guys, just thought I was so commonly on here you would know.
My mistake 2.7 bi.
My mistake 2.7 bi.
- shineydave
to be fair it could be from any one of the fleet of Audi courtesy cars lolMight help if you told people exactly what kind of car and motor this is from
2 true. Loll
But back to topic any help?
G
G
- 1st Gear
OK, I'm admittedly a noob here and don't know the personalities or what cars they have.
Repair manual says: "Check function of camshaft adjustment". Which means: with engine idling, go to Basic Settings, group 094. Then increase engine speed to over 2000 rpm. This will run a self-test on the valve timing adjustment. First it will show TEST ON, then either SYS OK or NOT OK in the 3rd and 4th fields. In the latter case, they want you to "Check solenoid valve for camshaft adjustment". Resistance should be 10 ... 18 Ω.
-Uwe-
-Uwe-
Will do , great lesson. will let you know.
G
G
System OK. Did it twice.
So no issue may be temp blip?
What do you think.
Great test thanks so much.
G
What do you think.
G
- 1st Gear
Then I wouldn't worry about it unless/until it comes back.
-Uwe-
-Uwe-
