Help with code please
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
flashyg
Post by flashyg » Sun Nov 19, 2006 1:24 am
17930 - Camshaft Adjustment; Bank 2: Malfunction P1522 — 35—10 — — — Intermittent
Readiness: 0000 0000
Only happened once I promise..
Any thoughts?
Uwe@Ross-Tech
RE: Help with code please
Post by Uwe@Ross-Tech » Sun Nov 19, 2006 4:18 pm
Might help if you told people exactly what kind of car and motor this is from.
-Uwe-
DavidT
Re: RE: Help with code please
Post by DavidT » Sun Nov 19, 2006 4:26 pm
Uwe@Ross-Tech wrote:Might help if you told people exactly what kind of car and motor this is from.
-Uwe-
He has a B5 RS4.
flashyg
RE: Re: RE: Help with code please
Post by flashyg » Mon Nov 20, 2006 5:07 pm
sorry guys, just thought I was so commonly on here you would know.
My mistake 2.7 bi. :oops:
shineydave
Post by shineydave » Mon Nov 20, 2006 6:42 pm
to be fair it could be from any one of the fleet of Audi courtesy cars lol
flashyg
Post by flashyg » Mon Nov 20, 2006 7:24 pm
2 true. Loll
But back to topic any help?
G
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Tue Nov 21, 2006 10:48 pm
OK, I'm admittedly a noob here and don't know the personalities or what cars they have.
Repair manual says: "Check function of camshaft adjustment". Which means: with engine idling, go to Basic Settings, group 094. Then increase engine speed to over 2000 rpm. This will run a self-test on the valve timing adjustment. First it will show TEST ON, then either SYS OK or NOT OK in the 3rd and 4th fields. In the latter case, they want you to "Check solenoid valve for camshaft adjustment". Resistance should be 10 ... 18 Ω.
-Uwe-
flashyg
Post by flashyg » Tue Nov 21, 2006 11:50 pm
Will do , great lesson. will let you know.
G
flashyg
Post by flashyg » Wed Nov 22, 2006 12:02 am
System OK. Did it twice. :P
So no issue may be temp blip?
What do you think.
Great test thanks so much.
G
:bigwave:
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Thu Nov 23, 2006 12:40 am
Then I wouldn't worry about it unless/until it comes back.
-Uwe-
flashyg
Post by flashyg » Thu Nov 23, 2006 10:20 pm
Thanks bud.
Return to “DTC / VCDS”
