Just Released - OBD connection via Bluetooth to Smartphone
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Nige_RS4
Post by Nige_RS4 » Tue Nov 01, 2005 1:04 pm
OK, so it's not going to replace VAG-COM, but if you just want to reset a DTC, this looks quite a useful tool.
http://www.vitalengineering.co.uk/smartphone/index.htm
EDIT - just seen the price of their bluetooth OBD connector - ouch!
Nige.
Dippy
RE: Just Released - OBD connection via Bluetooth to Smartpho
Post by Dippy » Tue Nov 01, 2005 1:43 pm
Don't think they've really done their market research very well.
2001 Silver S4 Avant
dazzer
Post by dazzer » Tue Nov 01, 2005 1:51 pm
Quite neat but a wee expensive.
Nige_RS4
Post by Nige_RS4 » Tue Nov 01, 2005 2:04 pm
I agree, especially when vag-check for the PDA is free .... http://www.arlab.it/vc/main.html
Now if only they could make the bluetooth dongle small enough to close the rear ashtray on the S4 / RS4....
SimonS4MTM
Post by SimonS4MTM » Tue Nov 01, 2005 2:35 pm
what lead do you need with this, could be good for checking fault codes on long journeys and leave the laptop at home
Nige_RS4
Post by Nige_RS4 » Tue Nov 01, 2005 2:41 pm
You can use a std PDA cradle. Mine had a serial cable and worked OK with my VAG-COM OBDII serial cable.
Dippy
Post by Dippy » Wed Nov 02, 2005 4:15 pm
SimonS4MTM wrote: could be good for checking fault codes on long journeys and leave the laptop at home
That's paranoia - or do you expect problems with your car on long journeys?
sinclair
OBD Bluetooth Transmitter
Post by sinclair » Wed Nov 23, 2005 11:44 pm
I'll be popping up to my Audi dealership in Whetstone to try and see what it is you are referring to.
As for the price, we are working on it.....
Sinclair
Vital Engineering Limited
peterb
Re: OBD Bluetooth Transmitter
Post by peterb » Thu Nov 24, 2005 10:25 am
You'll need to look at one of the older A4 models - the B5 (1995 - 2001). On these, the OBD socket is under the back seat ashtray lid at the rear of the centre console.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
cpufreak
Post by cpufreak » Thu Dec 01, 2005 12:39 am
I pretty much always take my laptop in the car when I go on any reasonable distance...and do regular datalogging, and scan for fault codes every 14 days or so.
My rationale is, if I log lots of data when everything is ok, I've got a good reference, so will easily be able to spot when somethings not quite right by comparing sets of data....i.e. a crude form of trend monitoring.
Equally as I make improvements to my car I can see what difference they make, not just instantly but also when they settle in. etc.
I'm aware I've an element of paranoia running through me, but also, I kinda see it as common sense,
andy
Return to “DTC / VCDS”
