up here in tayside / scotland , so if any one near this area that can help,,
all road test again tonight and see if its the same ,,
but would that be related to cam position sensor ??
fault code`s
- 1st Gear
Mine was miss behaving generally, most noticeable when cold, miss firing, jerky throttle response when pulling away, new MAF sorted this out totally.
when you say reset the fault codes do you mean erase if they are present or is this another function?
car now feeling alot crisper throughout!
did the exchange deal at local dealers and was surprised to get part of the tubing too-- thought it would of just been the sensor itself.
need
to do a run now with new one fitted and will post both before and after readings on your other thread (the widely viewed euro block figures) when i get chance for future help for stock runners cus its bin a great help to me up to now! cheers.
need
- 1st Gear
