How do you check mafs
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
lengster1
Post by lengster1 » Sat Dec 06, 2008 5:41 pm
Vagcom the car fairly often and suprised ive never lost one,do you have to do a power run and use the results to check the maf?
frazered
RE: How do you check mafs
Post by frazered » Sat Dec 06, 2008 8:39 pm
yup that is what i have done - 3rd gear log from 2k to limiter
tartan_rob
Post by tartan_rob » Sat Dec 06, 2008 11:08 pm
Unplug it.; If the cars runs same or better, it is stuffed.
2017 Kawasaki Z1000
2014 RS6
2014 S1
jimbo1234567
Post by jimbo1234567 » Sun Dec 07, 2008 1:45 am
you can check maf on vag as long as the car is fairly std. do it then post your logs. i think a std rs4 maxxes out the maf at 330 g/s ish, so just see what it does . :beerchug:
lengster1
Post by lengster1 » Sun Dec 07, 2008 6:11 pm
Thanks fellas, I will try this out when i have her back in action,im pretty sure all is ok as its always performed well,but after replacing the pre cat lambdas thought it a good idea to check
tartan_rob
Post by tartan_rob » Sun Dec 07, 2008 10:40 pm
Some of the MAF's are crap. It is worthwhile checking periodically. Audi do exchange units quit cheap.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Return to “DTC / VCDS”
