how to get vagcom
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
lynchy
how to get vagcom
Post by lynchy » Wed Jul 09, 2008 3:11 pm
i have just treated my self to a new laptop and i want to get vagcom installed how do you do this ? i have a b5 rs4 so what program do i install and what type of leads do i need .
Jarv
Post by Jarv » Wed Jul 09, 2008 9:50 pm
Hi lyncy,
Glad you've sorted yourself out a lap-top. I'd go for a genuine lead from Ross-Tech if I were you. Assuming that your lap-top has a USB port, then I'd go for the Key USB lead at $249:
http://www.ross-tech.com/Merchant2/merc ... ode=VAGCOM
Once you've got it you just need to plug it in and download the software from here:
http://www.ross-tech.com/vcds/download/current.html
and you're in business.
HTH
Mike
Mike
Q7
PetrolDave
Post by PetrolDave » Thu Jul 10, 2008 10:44 am
Jarv wrote:I'd go for a genuine lead from Ross-Tech if I were you.
Second that I've seen so many cases where people have bought a cheap lead off eBay which has:
a) broken fairly quickly, or failed to install the correct drivers; and
b) restricts the version of VAG-COM you can run to a very old version that limits what you can do (can't see all controllers and can't modify all adaptation channels).
The eBay route might seem attractive, but it will almost certainly be more stressful and could well be a waste of money. Bite the bullet and buy the "real deal".
Dom81
Post by Dom81 » Thu Jul 10, 2008 11:32 am
Thirded...
2007 Daytona RS4 Avant
Return to “DTC / VCDS”
