Any idea what this means:
1 Fault Found:
01616 - Signal wire to Interior Monitor
49-10 - No Communications - Intermittent
Thanks !!!
Central Conv. Fault Code Address 46 (B7 RS4)
RE: Central Conv. Fault Code Address 46 (B7 RS4)
Ummm..... anyone...???
Maybe rear window break glass detector???
There should be a separate interior monitoring control module, but without seeing a full scan its hard to give you anything detailed. However, it is an intermittent fault - did you have any problems except the code itself?
Sebastian @ Ross-Tech.com
Users browsing this forum: No registered users and 31 guests
