VAGCOM fault.
- nickelvery
VAGCOM fault.
I ran VAGCOM today and found this fault. I also noticed that when slamming on the brakes there is a noise from the front left wheel. Like an ABS sound.
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 00899
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Any ideas, thanks in advance.
Nick
Coding: 04395
Shop #: WSC 00899
1 Fault Found:
Nick
The next AudiMeets event is Sunday 13th July
www.AudiMeets.co.uk
http://i82.photobucket.com/albums/j250/ ... banner.jpg
www.AudiMeets.co.uk
RE: VAGCOM fault.
Could the ABS sensor be faulty - I had both front ones go on mine. However I was getting a judder upon slow stopping just before the car actually stopped - not really a sound like you say.
Edgy
Edgy
Avus RS4 - 710N's - MRC Custom Remap
RE: VAGCOM fault.
the load signal is generated by the air mass meter,check your maf readings
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
- nickelvery
Re: RE: VAGCOM fault.
What even though it's to do with the brakes?imolas4uk wrote:the load signal is generated by the air mass meter,check your maf readings
I'll have a look today.
Nick
www.AudiMeets.co.uk
www.AudiMeets.co.uk
- shineydave
the ESP reduces power by taking into account the load signal from the MAF so if you have a faulty MAF it can show a ESP/ABS fault since the ABS and ESP use the same sensors
Updated our WIKI to cover this code...
http://wiki.ross-tech.com/index.php/18265/P1857/006231
...and as suggsted before thise code usually comes in combination with codes in the Engine Control Unit (ECU). Your code is intermittent which means the related Engine Control Unit (ECU) code may already be cleared, but you should check for fault codes there too. A common cause for this would be a bad MAF.
Sebastian @ Ross-Tech.com
- nickelvery
Thanks for all your replies, which brings me on to how much does a MAF cost?
Thanks in advance
Nick
Thanks in advance
Nick
www.AudiMeets.co.uk
www.AudiMeets.co.uk
- nickelvery
MarkB wrote:About £75 for an exchange unit from Audi
Thank you.
www.AudiMeets.co.uk
www.AudiMeets.co.uk
