Help with this code
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
jimbogrey
Help with this code
Post by jimbogrey » Fri Nov 24, 2006 2:12 pm
17774 - cylinder 4 ignition circuit : short to ground
P1366 - 35-10- - - Intermittent
Have also had same but with cylinder 6
Any Ideas
Jimbo
MarkB
RE: Help with this code
Post by MarkB » Fri Nov 24, 2006 2:41 pm
I had this, or similar on my car when i got it. cleared it an it never came back. I assumed it was one of the coil packs shorting to ground.
Mark
S2tuner
Trader (Expired)
Post by S2tuner » Fri Nov 24, 2006 4:05 pm
Check the connectors on the ignition amplifiers on top of the airbox. A disconnected coil pack can't throw a code because it's not connected straight to the ECU, the signal first goes through the power output stages(POS) or ignition amps.
HTH,
Mihnea
MarkB
Re: RE: Help with this code
Post by MarkB » Fri Nov 24, 2006 4:09 pm
S2tuner wrote:Check the connectors on the ignition amplifiers on top of the airbox. A disconnected coil pack can't throw a code because it's not connected straight to the ECU, the signal first goes through the power output stages(POS) or ignition amps.
HTH,
Mihnea
Thats really helpfull. Never even thought about the fact that it would need to communicate back to the ecu. Easier to get to also...
Mark
jimbogrey
Post by jimbogrey » Sun Nov 26, 2006 11:36 pm
HTH,
Mihnea
thanks for that
jimbo
s4woody
RE: Re: RE: Help with this code
Post by s4woody » Mon Nov 27, 2006 12:53 am
and if you need 1 to test against let me know..i have 2 spare from my RS4 airbox..
GARTH ROAD MOT CENTRE LTD
020 83353032
Return to “DTC / VCDS”
