vag com download
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
kies4
vag com download
Post by kies4 » Wed Apr 19, 2006 4:52 pm
I've downloaded vag-com 512.4 hex-com I bought a lead ages ago off ebay but i can't get past the port test on com1.
Have i got the right software ? the lead doesn't look expensve but has the right connector for the car and com port.
I tried this with the engine running. I've seen the MRC boys doing it
kieran
S4 Crazy Horse. Ringsticker & MRC black magic.
Nige_RS4
RE: vag com download
Post by Nige_RS4 » Wed Apr 19, 2006 4:58 pm
You don't need the engine running, just the ignition on - I suspect it will be something to do with activesync, phone s/w or something similar hogging your com port.
I run an old P200 laptop for my vag-com - windows 98 and nothing else loaded or running in the background.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
maxxximus
Post by maxxximus » Wed Apr 19, 2006 5:31 pm
Is it a dumb interface - no dongle just a lead - think Ross tech only do the Hex-com+Can now. If it is you might have to use an earlier version - 409.1.
Also test all 4 com ports whilst plugged in and ignition on. You might have to adjust the baud rate(low one such as 1200) aswell. Ross techs website is a good start.
rolskii
Post by rolskii » Fri Apr 21, 2006 9:51 am
I go with Maxxximus.... spot on ....... undongled mate .... so unactivated ... :thumbsdown:
MarkB
Post by MarkB » Fri Apr 21, 2006 10:32 am
Any non genuine Vag-com lead will only work upto version 409. You still need to buy a license to fully unlock this version also.
Mark
Return to “DTC / VCDS”
