vag com help
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
GrimReaper
vag com help
Post by GrimReaper » Fri Feb 24, 2006 8:15 pm
Got a few codes that need deleting but can't seem to find the vag com port. Have searched the car high and low and its driving me crazy so help is needed. Knowing my luck its really obvious with a day glow arrow pointing to it :lol: Its a facelift version if that makes a difference.
Cheers.
Steve
shineydave
RE: vag com help
Post by shineydave » Fri Feb 24, 2006 8:17 pm
open the rear ashtray, it's under a sliding cover to the left of the tray, little electrical symbol embossed on the cover
GrimReaper
Post by GrimReaper » Fri Feb 24, 2006 8:25 pm
Balls i was hoping you wouldn't say that. I saw the symbol and lifted the cover up and its just a hole dunno if someone has pushed it down through or something. Also what connector does it use as i have the obd 2 connector left over from my Leon. Looking at the hole though my lead connector is way to big, is there a converter that attaches to the obd 2 or do i need another lead.
shineydave
Post by shineydave » Fri Feb 24, 2006 8:59 pm
as far as i know it's just a standard OBD2 socket, if it helps mines a pink one
Dippy
Post by Dippy » Mon Feb 27, 2006 1:56 pm
What car do you have? Some cars have the connector next to the driver's side knee bolster.
Take a look at http://www.ross-tech.com/vag-com/cars/dlc.html
2001 Silver S4 Avant
GrimReaper
Post by GrimReaper » Wed Mar 01, 2006 7:41 pm
I have a facelift S4 (B5 MY00). Will try the obd 2 connector tomorrow when i unscrew the the centre consol to find where the hell the vag connector as gone. Its defo located next to rear ashtray as its got the engine symbol stamped on the sliding cover. Think some one has pushed it it through though as there is just a hole where it used to be.
Nige_RS4
Post by Nige_RS4 » Wed Mar 01, 2006 8:29 pm
You can pull the ashtray out and see pretty much everything there is to see!
GrimReaper
Post by GrimReaper » Thu Mar 02, 2006 8:13 pm
Finally got hold of it. Had to unbolt the rear end of the centre surround so i could lift it up enough to pop it back into the hole. Got the Vag-com to work aswell. The prob i found was that i tried the OBD 2 connector just on the hole b4 i put the Vag-com socket back in place and it wouldn't fit so assumed that it was the connector being the wrong size. When i replaced the Vag-com socket into the hole i noticed that i did have the right connector but i had to trim about 1mm all the way around the socket so i fit my OBD2 cdonnector. Its all done now so cheers for your help. :D
Return to “DTC / VCDS”
