matthew.lewis2
Post by matthew.lewis2 » Mon Jul 20, 2009 12:25 pm
Last edited by matthew.lewis2 on Tue Jul 16, 2013 3:46 pm, edited 1 time in total.
david7m
RE: Only 255whp - I have a problem.
Post by david7m » Mon Jul 20, 2009 1:00 pm
Ouch, that must be painfully slow to drive :(
APR 270bhp S3, Mixer K6 750
RS4-Chew
Post by RS4-Chew » Mon Jul 20, 2009 1:46 pm
new engine so cant be coking......................?
maybe stuck exhaust flaps? air intake flaps?
fingers crossed for you buddy
07/57-B7 RS4 Saloon-Sprint Blue,Tech Pack, DRL's,Bluetooth,Carbon Trim,Chrome Optics,Sunroof,open zorst flaps,FBSW,Bose,Buckets,New Boots,R8 alu oil cap,BMC panel,RS plate,Fresh plugs,10mm Rear H+R spacers courtesy of Virdee.
Also - 1970 MGBGT for Hillclimbing and Sprint racing
03/53 - MK4 Deep Blue Pearl R32 3 door (sold)
"You never hear a truer word spoken in jest"
pippyrips
Post by pippyrips » Mon Jul 20, 2009 1:46 pm
Variences between dynos aside I think the norm. whp is around 300-310 so it does look low.
These engines are known for lossening up as the miles go on, 1k I very refresh. Also, what is the heat in Dubai ?!
m5killer
Post by m5killer » Mon Jul 20, 2009 2:28 pm
did not know you was in dubai, not surprised you are only getting that kind of power its got to be at least 40c+ im in bulgaria and the temp here is in the top thirties sometimes 43-44c and im way down on power, so i would say the heat is to blame ive been to dubai many times at this time of year so i know what it must be like at the moment, i even took my rs4 in to the mountains a few weeks back where it is much colder and the car was back to its normal self as soon as i came back down i lost loads of performance..
ArthurPE
Post by ArthurPE » Mon Jul 20, 2009 3:14 pm
is there a break in code on these cars?
limiting performance for say 1200 miles or first service?
looks like it's restricted > 5500 RPM
fell flat on its face and would not rev to redline apparently...
vaccum leaks, bad software, something is wrong
matthew.lewis2
Re: RE: Only 255whp - I have a problem.
Post by matthew.lewis2 » Mon Jul 20, 2009 4:35 pm
Last edited by matthew.lewis2 on Tue Jul 16, 2013 3:52 pm, edited 1 time in total.
PetrolDave
Post by PetrolDave » Mon Jul 20, 2009 4:49 pm
ArthurPE wrote:looks like it's restricted > 5500 RPM
The intake power flaps are supposed to open at 5500rpm, so worth checking for vacuum leaks?
matthew.lewis2
Post by matthew.lewis2 » Mon Jul 20, 2009 5:39 pm
Last edited by matthew.lewis2 on Tue Jul 16, 2013 3:53 pm, edited 1 time in total.
Blue_Thunder
Post by Blue_Thunder » Mon Jul 20, 2009 6:03 pm
Seems odd that the AFR is holding pretty much perfectly at 12.7 above 5000 rpms. If it was just a duff MAF would you not expect to see that figure going up and down as the ECU constantly corrected for the lambda readings? (unless the ECU is programmed to ignore the lamdba readings above a certain rev range)
Gazzer68
Re: Only 255whp - I have a problem.
Post by Gazzer68 » Mon Jul 20, 2009 6:14 pm
matthew.lewis2 wrote:Well, after 1000miles on my new engine I went to have the decats and remap installed.
According to the run in procedure, you should not use full throttle for 2500km and not more than 6000rpm up to 1000km then 7000rpm up to 2500km.
Your risking the integrity of your new engine, it hasn't been run in yet !
07/07 RS4 Avant Mugello Blue
matthew.lewis2
Post by matthew.lewis2 » Mon Jul 20, 2009 6:47 pm
Last edited by matthew.lewis2 on Tue Jul 16, 2013 3:54 pm, edited 1 time in total.
SR71
RE: Re: Only 255whp - I have a problem.
Post by SR71 » Mon Jul 20, 2009 8:25 pm
Mine and Andy's car generated ~305whp at an AFR of ~12.2 (above 5000rpm) which is richer than yours...ambient temp 22C.
The dyno correction factor suggests difference between 22C and 30C is ~1.5%
Your car seems to be doing whatever Mac4RS's car is doing...
Change out the ECU(s)?
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
PetrolDave
Post by PetrolDave » Tue Jul 21, 2009 10:04 am
matthew.lewis2 wrote:I was immediately on the phone to my contact in Audi technical department (not the dealers, but Audi M.E. HQ).
I hope that Audi M.E. have a better Technical Department than Audi UK have - they seem totally clueless (based on comments on most Audi owners websites and personal experience where they instructed the dealer to replace a sat nav under warranty when the dealer and I could both clearly see that it was the TV tuner that was faulty, so Audi UK picked up a warranty bill for a sat nav AND a TV tuner instead of just a TV tuner - that's £1500 wasted).
mac4RS
RE: Re: RE: Only 255whp - I have a problem.
Post by mac4RS » Tue Jul 21, 2009 2:39 pm
PM sent Matt.
