Screen Wash reservoir leak
Posted: Thu Jun 15, 2023 7:48 am
by RS4786
Hi guys as title will i have to remove bumper to repair leak from the screen wash res ? Can see drips from around the foglight area thanks
Re: Screen Wash reservoir leak
Posted: Thu Jun 15, 2023 12:20 pm
by delroyx
I think there is a pump which can leak which can be accessed through the wheel arch.
Pretty sure the resevoirs come in two parts
Posted: Thu Jun 15, 2023 12:23 pm
by delroyx
Are you sure it's not the aux rad or condensation from the air con. Guessing you've checked the obvious...screen wash level!?
Posted: Thu Jun 15, 2023 1:06 pm
by RS4786
delroyx wrote: ↑Thu Jun 15, 2023 12:20 pm
Leak is def from the washer res as can see it coming straight out when you top up plus warning light on dash
Will i just need to replace a seal o ring as pumps are working just dont hold fluid.
Posted: Mon Jun 19, 2023 5:55 pm
by Spwong
I replaced a bunch of grommets around the washer reservoir, from my notes: "Replaced windshield pump grommet, sensor grommet, 2nd overflow tube grommet. Replaced several wheel arch liner fasteners and nuts. No leaks! Headlight pump grommet about the only one not changed". All were accessed by removing the wheel arch liner.
