Clutch parts
Posted: Wed Feb 14, 2018 12:02 pm
by Lukes3
Just a quick one lads,
I am havibg my clutch done in couple of weeks but i am supplying the parts,
Is there anything else you guys think i should have changed whilst its been done?
So far the parts i have got together are...
Clutch friction disc
Clutch pressure plate
release bearing
Release bearing guide sleeve
New clutch fork
And the uprated clutch pipe from this forum.
Maybe slave cylinder?
Re: Clutch parts
Posted: Wed Feb 14, 2018 12:36 pm
by DavidRS4
How many miles has the car done?
Flywheel should be fine?
Re: Clutch parts
Posted: Wed Feb 14, 2018 7:49 pm
by Lukes3
DavidRS4 wrote: ↑Wed Feb 14, 2018 12:36 pm
Yes mate flywheel is fine so i am leaving it for know prob change it all next time.
Re: Clutch parts
Posted: Thu Feb 15, 2018 2:12 pm
by Callumrobin
It's a big job mate as had mine done a couple of weeks ago, I would highly recommend changing the flywheel at the same time as it's all apart, bit more money but will save in the long run!
I went for the single mass conversion but you will need to supply the bolts with that, Euro car parts sell all clutch bits you need and if you time it right then you should get it all for a steal. Only thing the kit doesn't come with is the thrust bearing, you'll need to source that.
Re: Clutch parts
Posted: Thu Feb 15, 2018 11:08 pm
by Lukes3
Ok cheers for that pal,
Today i had a phone call about the clutch i have brought, an rumour has it that sachs have had a few problems with there performance clutch kits? Breaking up/exploding!?
Has any heard anything at all about this?
Re: Clutch parts
Posted: Fri Feb 16, 2018 8:36 am
by DavidRS4
Send it back and go for a JH Motorsports setup. Tried and tested to death
